Originally posted by coloseu 1 -Relate AF to AE (AF/AE)
When multi-point AF is activated, exposure at metering segment with AF point which achieved focus will have more weight in the evaluation of the metering.
However, since the (11) AF points distribution is not exactly aligned with the 16 segments of the light meter cells, I doubt the usefulness and practicality of this feature.
Quote: 2 – AE-L with AF locked
This should be enabled for most of the time IMO. A quick check to the multi-segment metering of Pentax DSLRs by any user should reveal that the multi-pattern/segment logics tend to put *heavy* weight and emphasis on the centre segment.
It is therefore if the user uses only the central AF point only and then recompose more often, this features is a must for multi-segment metering or even centre-weighted average. Otherwise, metering will not be weighted on the subject where you focused. You have to push AE-L separately for precise metering anyway if this custom option is not enabled.
As for Spot metering, it is useful but for maximum flexibility and precise metering, I would still leave this option to "Off".
All other DSLRs of other brands actually lock AE with AF as default in green mode and in evaluative/multi-pattern/segment metering mode. In fact, only Pentax have to do it differently by default.
