Originally posted by bavd Actually, you probably mean "Your sort of photography........"
Enoeske's reactions really does not help much. It's like if to a person (who asks how to set the camera to better AF) advises that has to use manual focus - because if he needs autofocus, he do not want to do "photograph". I'm wondering why he is responding this way, I have always appreciated the very friendly atmosphere here at Pentax Forum, therefore I do not know why I should been critised just because I asked for the camera function, or advice on how to bypass its absence...
But thanks all of you, who want to help.
I will try P mode with fast shift and fast auto ISO. Today I will have good oportunity to test it in field.
Quote: Why would ISO 80 cause over exposure (picture too bright)? Do you mean under exposure?
Sounds to me that this is could just be metering incorrectly.
No - metering is fine. Its that if I use given aperture and shutter speed in TAv mode and conditions rapidly changes - correct exposure will be something about ISO 40 -but it cant bem so it leaves ISO80 end overexposure. This is not fault of mettering. Just lack of function in Av mode - shutter speed limiter (that limit shutter to do not set under given value you need),
PS: For the record, I can use Manual mode, I'm using it in certain situations, where I have a time. When I taking, for example, bird photos, I havent got time to fiddle with controls. I want to preset setting that suits my needs and let the camera auto set rest. I'm shoting for several years, but recently I have started to do some light wildlife. Thats all.
