When I load a RAW PEF file from my K-5 into the Capture One software program it works fine that is to be expected as the release notes say the 6.3 64-bit version of the program that I am testing in trial mode supports the K-5. But when I load a RAW DNG file from my K5 into the same program the colors go crazy for example deep blue, bright red or magenta appears as an awful magenta or purple blotch that also appears when a Tiff file is exported from the program so it is not just an issue with the viewer.
The same PEF and DNG files open fine in Photoshop with no problem.
I tried reloading the C1 program and using different versions but it made no difference, so I am wondering what is wrong
and if this is a known issue?
While dredging around on the internet for a solution I came across this explanation in a thread on another forum about a similar problem with files from a Canon DSLR on an earlier version of the C1 program that seems to make sense, even to an ignoramus like me:
Magenta cast in the highlights after RAW development is 99% of the times because of a bad saturation point considered by the RAW development software. So what you are experiencing here is a mismatch between your hardware and your software.
However it is surprising to encounter this problem in a reputable program like C1 that specifies in its release notes support for the K-5.
