Sorry had to run and forgot the link
PopPhoto.com: PSPX version 11.11 issue - View Post it shows what I could and then could not see. Anyway, not sure if the same is true if you just shot JPEG. I may try a experiment later.
If you don't want to read the link here is what is says:
Anyone find that when the crop a JPG in PSPXI that the EXIF info gets striped to minimul info?
It normally shows this:
EXIF Type EXIF Data
Make PENTAX Corporation
Model PENTAX *ist DS
X Resolution 300/0 dots per inch
Y Resolution 300/0 dots per inch
Resolution Unit Inch
Exposure Time 1/90 sec
F-Number F2.8
Exposure Program Aperture priority
ISO Speed Ratings 800
Date/Time Original 2006:12:08 19:15:27
Date/Time Digitized 2006:12:08 19:15:27
Exposure Bias Value 0
Metering Mode Center weighted average
Flash No flash fired, compulsory flash mode
Focal Length 110.0 mm
Sensing Method One-chip color area sensor
Custom Image Processing Normal
Exposure Mode Auto
White Balance Mode Manual
Focal Length in 35mm Film 165.0 mm
Scene Capture Type Standard
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Distant view
But if I crop anything it leaves only this:
EXIF Type EXIF Data
Compression JPEG compression
Orientation top, left side
X Resolution 72 dots per inch
Y Resolution 72 dots per inch
Software Paint Shop Pro Photo 11.11
Date/Time 2007:01:05 21:31:48
Thumbnail Offset 13304 bytes
Thumbnail Length 6418 bytes
YCbCr Positioning Datum point
Thumbnail Data [6418 bytes of thumbnail data]
IPTC Type IPTC Data
Directory Version 2
