04-14-2015, 01:13 AM   #1
Android tethering.
Anyone using it...?
Pentax and Samsung Tethered Capture for Android - DNA Software
Images show K5 tethered to Android device...
04-14-2015, 03:30 AM   #2
Ex Finn.'s Avatar
K20 connected in the video? Would be nice if it worked on the K5, maybe it does?
04-14-2015, 05:21 AM   #3
Price @ $30 you're 1\3 of the way to a Flucard which of course is wireless . Much more functional
04-14-2015, 05:49 AM   #4
Good thing to try if works well.
Only K3 works with Flucard. And I have a bunch of "older" cameras.
-- the only one feedback is not very positive. I wonder if there is anyone tried it.
04-14-2015, 07:08 AM   #5
PentaxJax's Avatar
They have a demo version. I might try it later.
04-14-2015, 11:24 AM   #6
Otis Memorial Pentaxian
The developer is a member here at Pentax Forums and has been soliciting test users for a Lightroom plugin for tethered operation from that program. With any luck they may check in here or if you have questions you can PM them:
DNA Software - View Profile - PentaxForums.com
04-14-2015, 11:37 AM   #7
PentaxJax's Avatar
Thanks for the link Steve, I had no idea this was being done. Interesting stuff....
05-02-2015, 07:57 AM - 1 Like   #8
sterretje's Avatar
So I took the challenge and hooked up a K5 with firmware 1.16 and FA31Ltd to the demo-application installed on my wife's Samsung S4. It basically works but has some issues
Tested in Av, TAv (except for the ISO testing below for obvious reasons) and M
aperture:
open/close works till opened to f/1.8; after that one has to use the camera to get it away from f/1.8
shutterspeed (exposure):
[+] gives sequence 1/8000 -> 1/4000 -> 1/2000 -> ..... ->15 -> 30; reverse order does not work but [-] sets 1/8000
iso:
one can go down from 12800 to 100 using [-]; one can only go one stop up when currently selected ISO is 100/200/400/...
exposure compensation (tested with 1/2 eV steps):
goes up to +8 eV using [+]; on the rear display of the camera, the 'cursor' goes outside the allocated area; [-] does not work
next [+] goes to -8 eV up; if compensation is negative, both [+] and [-] will bring it closer to 0
flash compensation:
only +0.5 eV; [-] does not work, [+] toggles between 0.0 and +0.5eV; if camera is set to anything but 0.0eV, [+] or [-] will set it to 0.0 eV
Other notes:
  • Camera controls remain functional; one can e.g set the flash compensation to -1eV using the camera,
  • Images can be view and zoomed in and a histogram is available.
  • The backlight of the top LCD flashes continuously at 2 or 3 flashes per second; possibly polling from the phone. I switched it off.
  • Photos are not stored on memory card; this might be normal for a tethering application, I don't know.
  • Does not work with K10D; the camera is not recognized in any of the connectivity settings (PC, PC-F and pictbridge).
  • If you have a Samsung Tab3 7", OTG does not work
  • Possibly because of the demo version, but the below image was not resized.
Below a 'sceenshot'
I hope this helps somebody in deciding.
android, camera, dslr, photography
Triggercord tethering software on Android, need your help c-meier Digital Processing, Software, and Printing 25 07-17-2015 04:20 PM
pktriggercord does Android rawr Digital Processing, Software, and Printing 4 03-31-2015 12:22 PM
Tethering ! marquis1955 Pentax K-5 15 12-13-2014 05:46 AM
Android tethering software? wowtip Digital Processing, Software, and Printing 4 08-16-2011 12:01 PM
All times are GMT -7. The time now is 10:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
