04-15-2015, 12:58 PM   #1
K-S2 wireless flash mode
Hello Pentax-Community.
I own the new Pentax K-S2 for a few days, (first Pentax) and so far, i am really satisfied! Now i am trying to use my external Flash with the Camera, but i cant find the "W-Flash" Setting in the Camera.
I bet/hope i am just to blind to find it! I already watched some camera tutorials on youtube, and other Pentax cameras seem to have that setting. Anyone can help me?
Thank you
Jens
04-15-2015, 01:11 PM   #2
Ole
Ole's Avatar
I don't know the S2 that well but perhaps you're in a exposure mode that doesn't support it? Try P or Tv mode perhaps.
04-15-2015, 01:21 PM   #3
QuoteOriginally posted by Ole Quote
Thank you for the Quick reply. Appearantly not. I've looked though all Modes.
All i find is -
Flash - Flash/red eye - Blub sync - bulb sync /red eye - 2nd Shutter - manual Flash
( i tried to translate this from my german menue, so the terms in the english menue might differ a little)
04-15-2015, 01:24 PM   #4
Check out page 116 in the K-S2 manual. It talks about External Flash and what modes are supported.
http://www.ricoh-imaging.co.jp/english/support/man-pdf/k-s2.pdf
04-15-2015, 01:34 PM   #5
QuoteOriginally posted by eminker Quote
This is interesting... it says
Never press 1
on the camera when any external flash unit
is attached to the camera. The built-in flash will hit the
external flash. If you want to use both at once, connect them
using an extension cord.
in the german manual it says "if you want to use both, chose wireless mode OR use an extension cord."
I feel like there might be no build in WL mode? :-(
( i own a metz AF58-2 with minolta/sony shoe and want to use it at least as a manual slave flash)
04-15-2015, 01:38 PM   #6
enoeske's Avatar
QuoteOriginally posted by n-light Quote
All i find is -
What lens are you using? P-TTL doesn't work with some older lenses.
04-15-2015, 01:39 PM   #7
UncleVanya's Avatar
I don't think the built in flash can trigger an external flash wirelessly. The manual doesn't have any directions for selecting the channel like the k50 does. Also the Ricoh website says this...
Ks2
External Flash
Type: Hotshoe (P-TTL), Leading Curtain Sync, Trailing Curtain Sync, Contrast-control-sync, High
speed sync, wireless sync (available with 2 dedicated external flash)
Synchronization speed: 1/180 sec
Note the wording, two dedicated external flash...vs.
K50
External Flash
Type: Hotshoe (P-TTL), high speed sync and wireless w PENTAX dedicated flash
04-15-2015, 02:09 PM   #8
CarlJF's Avatar
It seems that Pentax didn't included wireless flash control in the K-S2. Why they've done this is beyond me. But it's certainly a bad idea and a negative point of the K-S2. That said, you can find cheap P-TTL cable on ebay. Which are still useful to have even with bodies supporting wireless P-TTL...
04-15-2015, 02:17 PM   #9
The K-S2 definitely does not include Pentax's wireless flash control, an otherwise normal feature on this level of its camera lines (i.e., K-30/50). Why they took a step backwards here, given the fairly recent upgrades of their two main flashes, AF540FGZ II and AF360FGZ II, to weather-resistance and other improvements -- is beyond my understanding.
04-15-2015, 02:33 PM   #10
enoeske's Avatar
QuoteOriginally posted by Marktax Quote
That's very disappointing. I've never actually used the wireless P-TTL (I like setting my lights manually) but its sad to see something that's always been there get taken out of an otherwise fantastic looking camera.
04-15-2015, 02:34 PM - 1 Like   #11
lightbox's Avatar
Wow... I almost bought one of these!
I consider off-camera flash a basic photography technique. Much more so than WiFi and flipscreens.
04-15-2015, 02:46 PM   #12
Thank you guys. I guess its like you said. First disappointment in the new camera... this does really not make sense to me. Well.. still have the possibility to send it back. Gotta think about that.
@enoeske i am using a 35mm f2.4 .. newer lens.
Good night everyone.
04-15-2015, 03:31 PM   #13
CarlJF's Avatar
QuoteOriginally posted by lightbox Quote
Agree with you. And for Pentax, having it supported in the body is way more important than Canikon since there's no third party remote trigger that support wireless TTL. This will not be so bad if some cheap P-TTL radio trigger was available for Pentax, like the one from Yongnuo for Canon or Nikon.
04-15-2015, 03:32 PM - 1 Like   #14
I bought a FlashQ system for $39. This gives you radio signal wireless flash with ANY flash unit.
Works very well.. (No TTL)
Products – LightPix Labs
04-15-2015, 04:12 PM   #15
lightbox's Avatar
QuoteOriginally posted by CarlJF Quote
Does the Cactus V6 do it? This is from their product page:
TTL Pass-through
The V6 transceiver comes with a multi-system shoe that supports TTL pass through. With TTL pass-through, the TTL flashes behave as they would when directly connected to the camera hot shoe.
I just switched to Pentax from Nikon myself and so I already have Nikon flashguns. Unfortunately one thing I lost in the transition is the CLS system for wireless control and TTL. However, the K-50 *does* at least trigger remote flashes in optical slave mode, so manual flash setting still works. That's really all I absolutely need, and for that, even the cheapest radio triggers work. However, this is such a simple thing to put into the camera as a feature... don't know why they left it out in the KS-2. Hopefully it gets added back in a firmware update.
@Steve.Ledger Can you still mount the flash unit to a light stand while the FlashQ receiver is connected? The video makes it seem as though it's intended for hand-holding the flash. I'd be tempted to say that you can just use a TTL cable for that, but it seems the FlashQ is even cheaper than the Pentax cable! That's crazy.
camera, dslr, flash, k-s2, k-s2 wireless flash, pentax, photography, wireless flash mode, wl
Flash in wireless mode off but still firing shaolen Troubleshooting and Beginner Help 6 04-18-2014 05:48 PM
Wireless Flash Control Mode Unregistered User Pentax K-3 & K-3 II 11 02-24-2014 03:58 PM
Flash in wireless mode WA-surfer Flashes, Lighting, and Studio 3 05-29-2013 04:25 PM
Does kr flash like normal when it is set to wireless mode + controller mode? Zev23 Pentax K-r 8 05-24-2012 07:09 AM
K-7 flash in Wireless mode. Doesn't work correctly? Edvinas Pentax DSLR Discussion 7 09-07-2010 06:14 PM
All times are GMT -7. The time now is 04:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
