I would also be concerned that the Pentax (Ricoh) service center in Sweden will only be able to replace the main board. The flash memory chips use Ball Grid Array (BGA) packages which are normally programmed in circuit on the board.
During production I would suspect the JTAG boundary scan capabilities in the main chip (basically a shift register connected to all the pins) is used to configure the address and data lines to the memory chip and program the data. For updates, the main chip loads a program into RAM, which it runs to reprogram the memory chip. If power is lost during this reprogramming the flash memory is corrupt and the camera will not boot.
Whilst it's possible the service center has the necessary JTAG programming capability, I somehow doubt they would make the investment (easier to just replace the board). I have seen other posts where the US service center simply replaced the main board (returning the original with the camera).
Glad to hear that in this case the problem was not a corrupt firmware load.
