Originally posted by zmohie From what I understand that the work way of SR and tripod
is opposite so if I want to use the feature I have to turn the SR /ON/ and at the same time I have to put the camera on a tripod.how will this be working properly!
Originally posted by Alizarine The pixel-shift technology uses the SR mechanism to do its increase-dynamic-range thing. The 645Z's sensor doesn't have SR, so even with a firmware upgrade it isn't possible with the 645D/Z
So, if you are using the tripod for a shot that does not require (or you just don't want to) "PS", the SR should be OFF, as usual.
If you want to use PS, then you leave the SR "ON" ?
JP
