04-25-2015, 05:05 AM   #61
QuoteOriginally posted by zeds Quote
sorry.. I can't see a picture..,
They're thankfully not embedded (the first two are 14MB full sized jpeg files). Did you try clicking on the links?
04-25-2015, 09:03 AM   #62
You might have a browser setting prohibiting it. Works on mine. (That's what they all say)
04-25-2015, 11:02 AM   #63
Sorry, but shots look sharpened. You can see some relatively strong halos. I'd be interested in how it looks without any sharpening applied... how much detail is there really. Still, it looks good, can't deny that. Not sure if I _need_ it, but I would certainly make use of it once in a while, IF I can combine it with bracketing. If not, I'll take bracketing over this any day... the kind of shoots where I could use this I need significantly more dynamic range than just 14 EV or so.
04-25-2015, 03:44 PM   #64
QuoteOriginally posted by kadajawi Quote
Which photo are you referring to? I don't see halos in either of the pixel-shifted examples (#1, temple roofs and #2, flies and watch).
04-25-2015, 06:43 PM   #65
I don't see any halos or other artifacts that would indicate oversharpening. I like what I see. Might be enough to move me from my K-5.
04-25-2015, 08:03 PM   #66
JohnBee's Avatar
QuoteOriginally posted by Dice Quote
If you look closely around the edges of the bricks in the building scene and around the numbers on the watch face of the fishing hook scene, you'll definitely find classic sharpening halo's. Granted... you'll need to look closely, even magnified on the watch face, though it remains that they are definitely there nonetheless.
And while there's no denying this would never bother anyone where perceptual image viewing/printing are concerned. It goes without saying that this would present issues in where large image printing and upsizing are concerned. As these would inevitably get magnified along with the image.
PS. this is why I've come to love plugins such as Focal Blade, as it is one of the few tools that can sharpen an images with advanced features such as peak and halo controls.
04-25-2015, 09:37 PM   #67
QuoteOriginally posted by JohnBee Quote
Hmmmm...I did do a close examination of both the watch face and the brick edges and also the transitions to the OOF areas and saw no artifact. I don't generally use magnification since the accuracy is dependent on the tool. Any halo would only be a few pixels wide. Still though, that would indicate a characteristic of the in-camera RAW converter. A TIFF generated with a capable converter with no sharpening would be a better indicator. May I ask if similar artifact is present on the non-pixel shift images?
04-25-2015, 09:51 PM   #68
They are just (a) JPEGs and (b) produced in camera. Cut them some slack.
The image notes show those JPEGs have all been processed by the in-camera RAW converter [Processing software: K-3 II Ver.1.00(in-body RAW data development)] and had a Custom Image tone applied ['Vibrant', 'Bright', 'Portrait' etc], with some sharpness settings applied either specifically ['Sharpness: 1', or 'Fine Sharpness' ON or OFF], or with whatever sharpness algorithm is used in the JPEG quality settings employed by the camera's 'Super Fine' JPEG setting.
So some of those 'halos' people are seeing may be JPEG compression at work, not image sharpening.
Maybe one day Ricoh will make available the RAW's of those sample scenes, so people can process them without certain levels of JPEG compression and sharpening being baked into them.
04-25-2015, 09:54 PM   #69
JohnBee's Avatar
Hmmmm...I did do a close examination of both the watch face and the brick edges and also the transitions to the OOF areas and saw no artifact...
04-25-2015, 10:05 PM   #70
QuoteOriginally posted by Scobra Quote
Im hoping the next feature they incorporate is in-camera anti-ghosting. There seems to be unlimited room for software advances. For those who dont yet have the K3II, you could try this method A Practical Guide to Creating Superresolution Photos with Photoshop
I did that. I did a write up of it with images with and without SR.
It works quite well, but has some limitations. It takes about one hour of PS work per final image. The extra camera time is negligible.
https://www.pentaxforums.com/forums/38-photographic-technique/289384-super-re...ml#post3172702
04-25-2015, 10:20 PM   #71
photos of halo
Thanks...that is about two pixels. Is the same thing present in the non-SR images?
04-25-2015, 10:27 PM   #72
That 'halo' along the edges also looks a lot like what I see when CA/fringing is removed from an image by Lightroom, as you adjust the fringing width ...
Once again, JPEG processing options possibly at work.
04-25-2015, 10:38 PM   #73
I agree, I get the same from JPEGs out of my K3.
So not related to Pixel Shifting or any post processing trickery.
04-25-2015, 10:40 PM   #74
Answered my own question:
From the flower photo 400% magnification. I would suggest that the artifact is not evidence of any attempt to overstate the capabilities of the PS system. Bring on the TIFFs
04-25-2015, 10:46 PM   #75
Bring on the TIFFs
Better: bring on the DNG's.
birds, camera, dslr, image, k3ii pixel shifting, photo, photography, pixel, pixel shifting samples, post, ps, samples, samples from pentax, scenes, system, time
The k3ii is out... so what about the FF.. kooks Pentax Full Frame 31 05-17-2015 06:04 AM
Pixel Shifting on the new FF - The benefits mikeodial Pentax Full Frame 21 05-09-2015 11:37 PM
K3 II Full specs and pixel shifting! deaning Pentax K-3 1 04-22-2015 03:12 AM
Imaging Resource Article on Ricoh Pixel-Shifting mgvh Pentax DSLR Discussion 26 03-30-2015 05:03 AM
Super resolution by pixel shifting in future Pentax cameras Mistral75 Pentax News and Rumors 190 03-29-2015 04:31 AM
All times are GMT -7. The time now is 10:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
