04-27-2015, 11:43 AM   #1
Infrared camera control from BEHIND camera?
Are any devices available for controlling Pentax K-r cameras from the rear of the camera, specifically shutter actuation? This seems to be one major function lacking Pentax K-r cameras. Any help or info would be greatly appreciated. Thanks BLR
04-27-2015, 11:54 AM   #2
blackcloudbrew's Avatar
? I'm somewhat confused by this comment. Most every Pentax DSLR body I own is IR controllable from both front and back using the IR remotes available for them.
04-27-2015, 11:58 AM   #3
crewl1's Avatar
Not only do most Pentax have rear IR sensor, if you are standing at the camera, many support a wired plug in remote also - like this Vello RS C1II Wired Remote Switch for Select Canon Pentax Contax Samsung | eBay
04-27-2015, 12:00 PM   #4
AggieDad's Avatar
My K5-IIs can be controlled by an infra-red from either front or rear. I can even select a 3 second delay after actuation. I bought an remote on Amazon for about $6 and it works a treat.
04-27-2015, 12:12 PM   #5
PentaxJax's Avatar
QuoteOriginally posted by brieck Quote
Are any devices available for controlling Pentax cameras from the rear of the camera
I usually control my camera from behind, unless its time for a selfie :-) I don't remember if my K-r had a rear IR but the K-5 and K-3 do, there are a couple of Pentax and aftermarket remotes, and I still have my cable release from my ME super
04-27-2015, 12:29 PM   #6
pete-tarmigan's Avatar
Are any devices available for controlling Pentax cameras from the rear of the camera, specifically shutter actuation? This seems to be one major function lacking in ALL Pentax cameras. Any help or info would be greatly appreciated. Thanks BLR
Pentax Remote Control F, and
Pentax Remote Control WP
Miscellaneous - Pentax Camera Accessory Review Database
04-27-2015, 12:29 PM   #7
boriscleto's Avatar
QuoteOriginally posted by PentaxJax Quote
The low-end cameras did not have a rear IR port. At least the K-x & K-r didn't.
04-27-2015, 12:33 PM   #8
mike.hiran's Avatar
I think the k50, k30, and kx did not have rear mounted IR sensors, only in the front.
A pair of Cactus V6's can be used to trigger the camera remotely even through walls.
04-27-2015, 12:37 PM   #9
QuoteOriginally posted by boriscleto Quote
Thanks very much boriscleto----I didn't think the K-r had one, alas that was not the answer I wanted to hear.
04-27-2015, 12:40 PM   #10
LensBeginner's Avatar
Have you thought about redirecting the IR with some tinfoil?
Tape it to the front IR sensor so that it gets a reflection from behind and aim the remote at the tinfoil.
Might just work - it's not very practical, but at least it's feasible.
04-27-2015, 12:41 PM   #11
TER-OR's Avatar
I got on this Kickstarter.
https://www.kickstarter.com/projects/702400282/maxstone-iphone-your-camera
Uses your phone's bluetooth. The remote has an IR emitter and bluetooth connection. Works really well. Since bluetooth isn't line-of-sight, there could be an advantage.
---------- Post added 04-27-15 at 02:42 PM ----------
QuoteOriginally posted by LensBeginner Quote
Yes, a mirror should easily do the trick. It may not even need to be a very good mirror - like the foil.
04-27-2015, 12:52 PM   #12
Otis Memorial Pentaxian
QuoteOriginally posted by vagrant10 Quote
??? I thought the V6 was a wireless flash trigger.
04-27-2015, 01:03 PM   #13
PentaxJax's Avatar
Cactus V6 Review - Further Special Features | PentaxForums.com Reviews
04-27-2015, 01:41 PM   #14
Ok...so it requires the wired remote port on the body. Very clever.
04-27-2015, 04:12 PM   #15
Yeah, once you try using radio triggers, you'll wonder why you ever fussed about with IR remotes.
bluetooth, camera, camera control, cameras, dslr, ir, mirror, pentax, photography, tinfoil
Pentax Real control camera. Steelski Pentax DSLR Discussion 12 11-14-2013 06:51 AM
Converting Camera for Infrared Photography Spodeworld Troubleshooting and Beginner Help 5 05-24-2013 09:29 AM
For Sale - Sold: 3 Remote Control F, One Waterproof Infrared Remote Control pntxjack Sold Items 2 03-14-2013 10:33 AM
i have ?? about turning my camera into an infrared camera lguckert79 Troubleshooting and Beginner Help 11 12-05-2010 07:08 PM
A few infrared shots with converted camera tcom Post Your Photos! 21 02-14-2009 08:46 AM
All times are GMT -7. The time now is 08:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
