06-08-2008, 07:25 AM   #1
expatCanuck's Avatar
K200D wizards - autobracket?
Greetings -
Wondering if I might be missing something.
If I'm understanding the functionality correctly, autobracket should fire off 3 shots in a row -- one normal, one more exposed, one less exposed (tho' I don't know the specific order). Is that correct?
If so, I'm wondering what I'm doing wrong.
Per the manual, I hit the Fn button, then up, then over to the right to select the autobracketing drive mode. I can then use the thumbwheel to specify if I want a .5, 1.0, 1.5 steps of bracketing.
The 'three-image' bracketing symbol appears in the LCD on top of the camera.
But ... when I click & hold down the shutter release, only one photo is taken.
Am I missing something?
Thanks.
- Richard
06-08-2008, 08:13 AM   #2
ChipB's Avatar
Richard, on my *ist DS autobracket works just as you described - select it via the Fn menu, hit "ok" twice, then shoot. I tried it, and it fired off 3 shots (well, 4, but I didn't lift my finger off the shutter release ).
So, not sure what's up with your camera - check & make sure the autobracket symbol is visable in the LCD panel then test it again.
06-08-2008, 08:23 AM   #3
heliphoto's Avatar
What they don't seem to tell you is you have to hold down the shutter release untill all three shots are taken. I figured that out by accident.
Incidentally, you can change the order in which they're taken in the custom menu, but I like the default the best (the normal exposure's first).
EDIT: ok looks like you are holding down the button...hmmm...now I don't feel so helpful.
06-08-2008, 08:37 AM   #4
MnR
Hi,
I don't remember off hand, But I think you have select it the menu also...
06-08-2008, 09:44 AM   #5
QuoteOriginally posted by ChipB Quote
Chip -
Hmmm. Maybe it was hitting OK the second time. Maybe some karmic happenstance.
But all is now well.
Thanks.
- Richard
camera, dslr, photography
need pocket wizards for Metz 58? kewpie-o Flashes, Lighting, and Studio 6 03-04-2010 12:10 PM
Autobracket feature on K200D atomx Troubleshooting and Beginner Help 4 07-05-2009 02:43 AM
V2's Pocket wizards, Skyports etc Which do you have and use? Peter Zack Pentax Camera and Field Accessories 24 05-24-2008 05:59 PM
Autobracket question Luap777 Pentax DSLR Discussion 2 11-27-2007 04:17 PM
TSA and Pocket Wizards roscot General Talk 8 11-13-2007 07:21 PM
All times are GMT -7. The time now is 08:09 PM. | See also: NikonForums.com, part of our network of photo forums!
