06-08-2008, 07:49 AM   #1
K20D softness, intermittent
I am noticing that my K20 sometimes gives me results that look like a 'glow' has been added in Photoshop, kind of a soft focus look. It looks like it was sharp, then softened after. It will do this for a few shots, then things will look sharp as a tack. Adding some sharpening in PP helps, but it doesn't look nearly as good as the ones that are sharp right out of the camera. Any ideas?
06-08-2008, 08:01 AM   #2
Wheatfield's Avatar
QuoteOriginally posted by davemdsn Quote
What lens Dave? That sounds more like a veiling flare problem than a camera problem. Could you attach an example?
Thanks
06-08-2008, 08:05 AM   #3
morfic's Avatar
In what kind of light does this mostly occur? I seem to get the occasional front focused soft shot in flourescent lighting with my camera.
Wide open, a little bit of out of focus and you get a nice soft glow effect with about any lens.
06-08-2008, 05:01 PM   #4
Well, I went to upload an example, but I think I found the common denominator in the bad photos. Tamron 28-75 f2.8, wide open (2.8-3.5) at near infinity focus. It is never the sharpest wide open, but at closer focus it does better than this. I have obviously found it's weak spot. I normally use this lens from within 10 feet and with strobes so these results were fairly new for me. I hope that's the problem because that is fixable (don't shoot that lens wide open at long distances). I have other lenses that are better for those shots.
camera, dslr, photography
Intermittent blurred pictures with K20D fozzy Pentax DSLR Discussion 13 09-19-2010 05:05 AM
Front dial intermittent issue on the K20D jpzk Pentax DSLR Discussion 8 09-03-2010 05:37 PM
sharpness, softness, etc houstonmacgregor Pentax SLR Lens Discussion 4 08-02-2010 09:49 AM
Nature Softness Rense Post Your Photos! 4 10-27-2009 04:55 AM
softness shooz Photo Critique 5 08-11-2009 11:55 AM
All times are GMT -7. The time now is 09:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
