06-08-2008, 04:40 PM   #1
Pentax *istD not recording aperture and not taking photos.
Well, I got that memory card problem solved (a CF card wasn't necessary but the camera doesn't work with any capacity larger than 1 Gig as Photo Tramp had suggested).
Now the new problem is the camera doesn't detect the lens aperture. (I'm assuming that's what F-- in the viewfinder means). I'm also guessing that the camera isn't detecting the lens at all. Needless to say the camera doesn't even take photos. (I tried 2 other lenses and got the same results.)
Any idea what is causing the new problem ?
Thanks.
06-08-2008, 09:06 PM   #2
jeffkrol's Avatar
QuoteOriginally posted by wolf Quote
Thanks.
download the manual.
Custom function... f stop other than A... on
What lenses?
06-09-2008, 03:28 AM   #3
Pentaxke's Avatar
Press [Menu](left top button next to LCD screen)
[Custom Function]
Scroll down until you get 'f-stop other than A'
That should be set to 'On'
That's all. Pretty sure, the thing will work now.
Also, you are not saying what lens you are using, but if the lens has an A setting, better set it to A, then you can use all modes, without any hassle...
Also: download the latest firmware for the ist D here... The latest firmware is 1.12, although with 1.10 and 1.11 you are also in the safe zone... This latest firmware will make able to use CF cards that are more than 1 GB. I use 2 and 4 GB without any problem...
Have fun with the ist D. It's one of the best camera's made... Ever!
06-09-2008, 03:53 AM   #4
ftpaddict's Avatar
You didn't specify what kind of lens you use.
06-09-2008, 05:05 AM   #5
Lowell Goudge's Avatar
this is incorrect. I use a 4GB all the time in my *istD. the last software update made this possible. check the pentax web site for the last update and functionality
Thanks.
what lenses are you using? and are they in A mode.
Also you need to (for non A lenses) set the function for use apature ring
06-09-2008, 11:20 PM   #6
Yes, I'd say the "problem" was not having it on the "A" setting. Thanks to all of you for the information. To answer all of your questions, I am using a 50mm Macro lens. I also tried 2 other lenses (20 mm wide angle and 70-300 mm zoom and those didn't work either).
Thanks again.
aperture, camera, card, dslr, lens, pentax *istd, photography
Landscape Taking photos while driving pdxbmw Post Your Photos! 7 03-19-2011 11:56 PM
Taking photos for money fractal Photographic Technique 8 06-09-2010 11:10 PM
K200D Stopped Taking Photos itrs Troubleshooting and Beginner Help 4 10-18-2009 04:23 AM
keep taking photos on an angle :( Keebler Photographic Technique 21 04-15-2009 06:58 AM
Pentax *istD not detecting aperture setting and not taking photos. wolf Pentax DSLR Discussion 2 06-08-2008 07:12 PM
All times are GMT -7. The time now is 11:34 AM. | See also: NikonForums.com, part of our network of photo forums!
