Originally posted by wolf Well, I got that memory card problem solved (a CF card wasn't necessary but the camera doesn't work with any capacity larger than 1 Gig as Photo Tramp had suggested).
Now the new problem is the camera doesn't detect the lens aperture. (I'm assuming that's what F-- in the viewfinder means). I'm also guessing that the camera isn't detecting the lens at all. Needless to say the camera doesn't even take photos. (I tried 2 other lenses and got the same results.)
Any idea what is causing the new problem ?
Thanks.
Try cleaning the electrical contacts on the lens mount. I use a clean pencil eraser for this, keeping the body positioned in such a way that stray rubber bits that may scrape off can't fall into the camera, though you shouldn't be rubbing all that hard anyway. This is presuming that you are using A series or later lenses with the aperture ring in the A position. If you are using a non A series lens, or have the aperture off the A position, then you are seeing normal behaviour.
