05-31-2015, 03:03 PM   #1
Dewman's Avatar
In-camera jpeg sharpening.
Do any of you use it? If so, how much? (I've tried it and can tell very little, if any difference. I will ASSUME this is my poor eyesight and NOT faulty cameras.) Is it possible to use "too much" in-camera sharpening?
05-31-2015, 03:05 PM   #2
QuoteOriginally posted by Dewman Quote
It's certainly possible to over-sharpen. I usually leave the slider in the middle, though sometimes it's better to turn it all the way down and sharpen in post.
05-31-2015, 03:36 PM   #3
Na Horuk's Avatar
In your camera's Info menu, you can select the jpeg mode. There you press Info again and you can adjust it. You can adjust the amount of sharpening, and even the type (regular and fine. Not sure what the differences are, there has been some debate, but we have no official explanation as far as I know). Yes, there can be too much. Just try it, take two photos, one with default setting and one with max setting.
05-31-2015, 05:43 PM   #4
Yes it is especially if you are using a camera such as the K-5IIs or the K3 that come without the AA filter. I sometimes have to turn down the in-camera sharpening to avoid moire or other unpleasant artifacts.
06-01-2015, 02:40 PM   #5
Never
Definitely
06-11-2015, 03:38 PM   #6
mcgregni's Avatar
If you're looking on the camera LCD screen then I'd doubt there would be much difference to see. But viewed large on a computer monitor then you should see noticeable differences, certainly with more than 1 step adjustments.
I believe the ' fine 1 ' and ' fine 2' settings work on a smaller radius of pixels than the general sharpening slider .... So they would affect finer details such as trees and foliage, sand etc.
camera, dslr, in-camera, in-camera jpeg, photography
In-camera sharpening adjust question ps1984 Pentax K-30 & K-50 11 04-19-2015 06:13 PM
in camera sharpening K5 redbusa Pentax K-5 5 10-04-2012 05:50 PM
B&W sharpening in RAW, jpeg FHPhotographer Digital Processing, Software, and Printing 4 11-23-2009 06:30 PM
RAW and In-Camera Sharpening NicholasN Pentax DSLR Discussion 9 01-05-2009 02:13 PM
In your opinion, which is better... in camera sharpening or photo editor? slip Pentax DSLR Discussion 17 12-05-2006 03:35 AM
All times are GMT -7. The time now is 07:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
