06-11-2008, 07:05 PM   #1
enrod666's Avatar
k10d and flash af-360fgz
Hello,
I recently replaced my Ist*-D by a k10d. I have a af-360fgz flash. I have noticed that I can't get the same result with my k10d when I use this flash. It seems like I am always underexposed. I never had this problem with my Ist*-D. I tried a bunch of stuff like P mode, green mode, different ISO, speed, aperture etc...
My set-up on the flash is P-TTL with A.Zoom, I use the same lens on the k10d and Ist* which is a 18-55mm DA.
Can someone help. I don't understand why I have such difference in performance.
Thanks a lot.
Gerald
06-12-2008, 02:52 AM   #2
I also have problem with fgz 360 and k10d with smc-dfa 100mm 2,8 macro and It also underexpose and now when I shout macro I usally have to use +2,5 to get normal exposed photos but sometimes it works find but then In the middle of a photosession its starts to underexpose without me changing anything its strange and frustrating .
Kindly bjorsa
06-12-2008, 08:17 AM   #3
I would first check to make sure that an old flash ec setting wasn't dialed in. Then I would make sure that I was waiting for the flash to fully charge before shooting. I would also check to make sure that I'm within the flash's effective range for whatever iso and aperture setting I'm using.
06-12-2008, 06:48 PM   #4
enrod666's Avatar
Hello bjorsa,
Thanks for your comments. I set my flash at +1.0 and I get a much better result, acceptable I would say. But I can only go up to +1.0 not +2.5. I ajust this by pressing the Fn button and then I go in the flash menu. Is there another place to change that?
Thanks a lot.
P.S: I upgraded my firmware from 1.0 to 1.3 without a better result...
06-12-2008, 08:58 PM   #5
i thought i was the only one
a lot of times i get much better exposure with the camera's built in flash
Dave
06-12-2008, 09:17 PM   #6
danielchtong's Avatar
QuoteOriginally posted by enrod666 Quote
Hello,
Gerald
I think both AF360 and Ist*-D can do TTL instead. Can some guru correct me?
QuoteOriginally posted by bjorsa Quote
Kindly bjorsa
I broke my AF360 and currently I am using Sigma 500ST. Before it was broken, all I did was to turn off the camera and flash and turned it back on. No clue why all of a sudden the flash combo went haywire. Resetting it solved the problem though ( until the problem recurred).
Daniel
06-13-2008, 03:39 AM   #7
No... it doesn't do TTL with K10D....only P-TTL which in my experience completely sucks. It will work TTL on the older cameras. TTL works awesome on my older Pentax cameras. P-TTL is just inconsistent for me. Very disappointing.
06-13-2008, 03:50 AM   #8
I believe the last bodies to support TTL were the DS and the D.
06-13-2008, 04:52 PM   #9
enrod666's Avatar
According to what I can read should I get rid of my current flash af-360 fgz and buy something else. What would be the best match for my k10D ??
af-360fgz, camera, dslr, flash, k10d, mode, photography
For Sale - Sold: Pentax AF-360FGZ Flash (US) maconmatt Sold Items 4 11-07-2010 02:25 PM
K20D and AF-360FGZ flash navcom Pentax DSLR Discussion 3 08-26-2009 06:43 PM
For Sale - Sold: K10D body (AF-360FGZ Flash too if wanted) mrpackerguy Sold Items 2 10-09-2008 01:50 PM
For Sale - Sold: K10D, DA 35mm Macro, 2x Macro, 360FGZ Flash, 70-210mm f4, m42 adapter and lens drivel Sold Items 19 08-19-2008 04:53 PM
All times are GMT -7. The time now is 05:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
