Originally posted by Dr. Zee Got my K-3 II body and 50mm manual yesterday. Did some throwaway shots last night. Frankly, it's spooky. I can take shots now that look just like the old shots, (color tone, composition, highlights, shadows), but while the old shots were totally unusable, these are sharp and fine grained.
The funny thing is, I think I have an aversion to shots like these from years of shooting with the K10D. They're usually orange from incandescent or sodium lamps, or a mix of orange, green and red from competing color temp bulbs, have saturated colors and heavy shadows. I usually import them, push them as far as I can in RAW, get them to the point that they're technically presentable but repulsively artificial. By then I'm convinced that they're irredeemable and I delete them and move on.
I see these shots, and I'm still sort of repulsed out of habit. It seems wrong somehow that they look just like my throwaways but are now perfectly usable.
I guess I expected the quality of the capture or the quality of the light to be different somehow, But it's not. They're the same photos but better rendered. This'll take some getting used to.
I also got a 95mbps memory card. That coupled with this incredibly nimble shutter... I can't believe the speed.
Hello,
There several possibilities to fix that for me:
- The white balance is likely wrong in your case (even through K3-II does a far better job at it). You can correct it manually or just remember to take a grey paper on the field and adjust the white balence with it (the last one is what the pro are doing.
- Even on RAWs, one must understand there a "base" rendering. This rendering give the default value for contrast, relative exposure of different colors etc. You might need to work a lot just ot get the kind of rendering/mood you need because you may need to shift very far from it and then your picture might look unnatural if your are not post-processor ninja... Or you can change the base rendering to already match more or less what you want. In DxO, by default you can choose between the rendering of maybe 50 camera from different brands or to a default neutral, softer rendering... or use DxO film pack to choose from more than 1 hundred base rendering that emulate the rendering of old films, including the grain if you want. On lightroom I must admit I don't know what you can do, but I'am sure there some possibilities and that you can find interresting plugins too.
- It is also likely if you are honest that the original scene has harsh, bad lighting to begin with. Your brain somewhat improve it, but still the lighting is bad. Likely there shadow in wrong place, the light is so-so... There is nothing arround first to take a shoot in good condition, good lighting, interresting place and so on... And if you can't change the place, to add lighting off your on. This come with flashs... Just a single cobra flash that you bounce on ceiling or that you use with a small diffused slightly deported with your hand improve the lighting dramatically.
Just look how different the colors tone are with or without flash:
With flash:
Without flash:
