06-19-2015, 01:06 PM   #1
K3 II sensor shift
I've managed to get some sensor shift images on to the Pentax software, one is 133mb and the same without sensor shift is 32mb. When I increase the magnification, some parts of the picture are smooth and some are heavily pixelated. I realise that any movement during the exposure will spoil things and parts of the outdoor still life may have moved but the results are very patchy. Has anyone tested the effect?
06-19-2015, 01:11 PM   #2
QuoteOriginally posted by pentasonic49 Quote
I don't own a K3 II, but you will certainly get best results shooting a fairly static scene using a tripod. The camera is taking four images and trying to stack them and if there is much movement in the scene you will get artifacts wherever things move.
06-19-2015, 01:20 PM   #3
I took a photo of a bunch of houses with some trees in the foreground the other day. There was a light breeze, and even that was enough to ruin parts of the image. The bottom line: make sure everything is stationary, including your setup and the scene
06-19-2015, 02:40 PM   #4
I used a tripod, 2 second delay, manual focus and exposure and a remote release. The 2 second delay lifts the mirror instantly.
06-19-2015, 05:49 PM   #5
Can someone please test the idea of taking a 4-part pixel shiftshot immediately followed by a single fifth "normal" RAW shot. Then in pp using the normal shot to burn in where pixel shifting has gone wonky.
I ask this because I am working towards buying another body real soon, so I wanna know I postponing is a good idea. At the moment I am favouring the K-S2, but every month is another price drop!
06-20-2015, 10:12 PM   #6
QuoteOriginally posted by Bagga_Txips Quote
This is a very good idea and hopefully there will be software that enables this workflow soon -- you shouldn't need that fifth shot. The pixel shift raw contains four separate fields, uncombined until converted into jpeg or tif or whatever your desired format is. It should be possible to use one of those fields in the raw file, demosaic it traditionally, then selectively paint that over the artifacted portion of the pixel shift image.
I agree it would be really nice.
06-21-2015, 02:59 AM   #7
My understanding is that the "RAW" shot contains within it four RAW files, that's why it is so big. You should be able to split the file after the fact and choose one of the four images, using Pentax's DCU program they send with the camera. You could then combine it with you pixel shifted image in Photoshop, or wherever.
06-21-2015, 03:08 AM   #8
You can just use one of the frames from the RAW file as its own image. More work than it's worth IMO, though.
06-21-2015, 03:49 PM   #9
QuoteOriginally posted by Quicksand Quote
Yes, the first image is a straight shot that may be converted directly. That is the fail-over with Adobe products which (correctly) identify the DNG as non-compliant.
06-21-2015, 04:02 PM   #10
It seems that there needs to be a convenient way to replace areas pixelated by movement with info from a single exposure if this tech is to be useful in the field shooting anything but rocks [that don't roll].
camera, dslr, k3 ii sensor, photography, sensor, shift
K3 II pixel-shift samples on IR. I'm impressed jonby Pentax K-3 42 06-02-2015 12:28 AM
sensor shift stitching? windhorse Pentax DSLR Discussion 2 04-12-2015 03:59 AM
Sensor shift gone wrong :( gyozaman Troubleshooting and Beginner Help 9 04-06-2015 08:24 AM
Sensor Shift + FF? slyseekr Pentax Full Frame 2 02-21-2015 07:45 PM
Pentax K3 with 40 MP via sensor shift troenaas Pentax News and Rumors 129 10-07-2013 09:06 PM
All times are GMT -7. The time now is 09:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
