06-26-2015, 12:58 PM   #16
Reliant K1000's Avatar
I use both Manual, A lenses, and fully auto (with autofocus) lenses, and I think that the auto with autofocus wears down the battery faster, as perhaps should be.
Maybe it's because I put the focus to MF when I find I'm going to use manual lenses for a while is why I don't experience as much drain when compared with other lenses? Perhaps then it won't "search" and try to send a signal? Might want to try that next time.
06-27-2015, 05:10 AM   #17
Is your rear lcd illuminated when you are focussing? Try pressing the info button a few times to switch it off. It could simply be that because you're manually focussing, the additional time spent doing that (compared to auto focus), is causing the rear lcd to be on longer than normal, which is draining the battery faster....
06-27-2015, 06:09 AM   #18
QuoteOriginally posted by robthebloke Quote
Good point robthebloke , it could also be that since I'm chimping more often I'm causing the battery to drain, but usually after a while, you get sort of "six sense" when your battery should go down. I'm not getting that with my manual lenses, I'm often shocked that the battery drained so quickly.
06-27-2015, 06:44 AM   #19
aleonx3's Avatar
QuoteOriginally posted by hjoseph7 Quote
That is strange, in your post #11, you said you did not use Liveview to focus with manual lenses.... now you said you do... using rear LCD drains battery power more than using the viewfinder.
06-27-2015, 07:10 AM   #20
QuoteOriginally posted by aleonx3 Quote
By chimping he means reviewing the picture on the LCD after taking the shot. It's different than live view because it only turns on the LCD when reviewing while live view keeps the LCD on full time.
06-27-2015, 07:32 AM   #21
Not a Number's Avatar
The meter might be on longer as exposure adjustments are being made. Using the green button will actuated the diaphragm stop-down thus consuming power. If AF-S is selected the screw-drive may actuate consuming power. More time may be spent chimping MF lenses to check the focus and exposure. All sorts of variables.
06-27-2015, 02:20 PM   #22
QuoteOriginally posted by Bruce Clark Quote
I don't believe the bar indicators accurately reflect battery capacity. My K-7 can stay on 5 bars for days on end and next time out it may start on 5 bars but almost instantly drop to 4 or 3 bars. If 5 bars is 100%, 3 bars is far less that 60% capacity. I take anything less than 5 bars as it is time to recharge.
It is extremely difficult to measure a battery and determine remaining capacity (as distinct from measuring energy in and out and learning from recent performance). I have only ever used the bars as a measure of 'good to go'/'not good to go'. Hence, the rapid fall off when past a certain threshold. I never use the bars as a measure of whether to charge, or not, when I have a chance.
07-25-2015, 08:02 PM   #23
Vintage Glass and Battery Life
Have used a lot of vintage glass including M42 screwmounts with adapters on my K-100D for the past couple of years until I got lazy and bought an 18-55 Auto Zoom for it. On the auto I minimize AF use and that camera does not have live view; as stated that LCD screen is an energy glutton as is AF.
Now I have a new K-50 with live view and it takes movies; I have a feeling that my battery usage is going to increase significantly.
07-25-2015, 08:13 PM   #24
QuoteOriginally posted by Uncle Jaque Quote
Did you get the AA adapter? Four Eneloops do better than the Li-Ion.
08-31-2015, 12:02 AM   #25
So I started leaving the camera, K-3, on continuously. This introduces a different problem. As I walk around the the camera bounces about on my belly which results in random pushing of buttons.
The other day two effects happened:
1. The colour setting of the jpgs was altered (the 4-way button). I noticed and worked out how to return to the setting I prefer.
2. The 4-way button resulted in resetting to interval shooting at about 1 per second. Noticed the first picture I took. Found the accidental reset.
3. Something happened and now the LCD stays on with the setting information and I cannot work out what to do to turn it off. I do not want the LCD on continuously because that duplicates info I can get from the screen on the top (redundant), it drains battery unnecessarily, it is illuminated all the time which is not good for my vision when taking pictures in dark situations and it draws attention to the fact I am using the camera (which I ind not good).
I searched but what search terms do you use to find a solution to this?
Anyone know how to turn off the rear screen. I cannot find it in the menu or anywhere else.
08-31-2015, 09:21 AM   #26
QuoteOriginally posted by tim60 Quote
I mainly keep my 4-way button in the focus point select mode and only switch them to the other mode when I need to change drive mode/white balance/etc. And I make sure I change them back to focus point select mode so if I accidentally bump the buttons I only move the focus point around, instead of messing up the photo settings.
Press the INFO button twice.
08-31-2015, 09:59 AM   #27
On board flash user?
08-31-2015, 12:22 PM   #28
Thanks. Got it back in proper behaviour now.
My pet peeve - the multi-function button strikes again.
09-01-2015, 11:07 AM   #29
A few days ago I read the Service Manual for K10d. (You'll find a link here ).
Chapter 33.3 lists up an estimate of the power consume for autofocus, zoom, releasing shutter,
charging flash, bulb, displaying playback image, displaying menu, etc. etc.
I made a copy of the table which you can see here. Releasing Shutter consume six times more power than displaying playback image?
Even "Reading playback image in the card by USB communication" as well as "Stand by for USB communication " consume much more than I was aware of.
The relations are most probably still valuable for the K7-5-3..
09-01-2015, 02:54 PM   #30
Lowell Goudge's Avatar
The battery on my K-5II drains pretty quickly when I use a manual lens. I would think an AF lens would draw more power but apparently its the other way around.
Are you using live view and focus peaking or the optical VF?
I would bet live view, holding the shuttere open etc draws a lot of power
battery, battery drain, camera, dslr, lens, photography
Serious battery drain! What could cause this? Dewman Troubleshooting and Beginner Help 29 07-18-2014 06:08 PM
Battery drain on PC connection Farside Troubleshooting and Beginner Help 14 09-16-2013 07:09 AM
Processor-intensive operations drain body battery even when grip battery is selected bwDraco Pentax K-5 1 07-08-2012 12:44 PM
Quite strange problem when I'm using manual lens kenl Pentax K-r 9 09-08-2011 05:35 PM
All times are GMT -7. The time now is 10:02 AM. | See also: NikonForums.com, part of our network of photo forums!
