Originally posted by stormdore Hey, guys. I was practicing with my kit lens for this month's photo contest. The rules state that the picture must be 25 mm focal length or less. The problem is - since my kit lens zooms from 18-55mm, how can I be sure that I'm staying below 25 mm? I've already taken some pictures and I'm not 100% sure if I stayed below 25 mm. Is there a way to check on my computer program (I'm using iPhoto)?
Any information would be helpful.
Terri
When shooting, just look at the zoom ring. On the 18-55, there is a mark for 24. Set it there or lower and you should be okay.
After shooting, take a look at the EXIF information. While viewing the image in the camera, press the info button. It will give you all the pertinent information. If the images are downloaded into the computer, you can also see all the info you need using the Pentax photo browser software. It will probably show up in the properties of the image in Windows, too. Right click on the image, then left click on Properties, the click on the advanced button to see the information.
