07-02-2015, 11:09 PM   #1
Is it possible to AF without the Data pin?
I'd like to set Focal length by hand and to have AF. I thought it should be possible but after some tries with a very thin paper, it seems that the camera(K-5 iis) stops to AF when the Data pin is not accessible. I want to eliminate the SR error when an old TC is attached. Any other idea how to make the SR to work correctly without buying a new TC is welcome
07-03-2015, 02:27 AM   #2
The SR should still work correctly, but perhaps you won't get optimal stabilization. There won't be any errors. I'm not aware of any settings to override the focal length setting, but perhaps there's a hardware workaround.
07-03-2015, 03:30 AM   #3
Lowell Goudge's Avatar
Most of the Pentax community has long since given up trying to get Pentax to add a TC correction factor.
It is not just shake reduction, it also impacts the shutter speeds vs focal length function , as well as PTTL flash, and all your exit data.
But now that Pentax has come out with a TC that does things correctly there is even less likelyhood they will correct this point, or allow others to do so
07-03-2015, 08:12 AM   #4
Thanks for answers. I still think that the PDAF could operate without the lens info (data pin) but as I see the screw drive is introduced in KAF -1989 together with the data pin. So, on some reason Pentax AF works only when lens info is available.
af, camera, data, dslr, photography, sr, tc
O-GPS1 and your EXIF data - When the GPS is on, it strips data from the EXIF? Sagitta Troubleshooting and Beginner Help 17 11-23-2016 02:25 AM
Ricoh pin - what is it and why the need to remove? GerryL Troubleshooting and Beginner Help 26 04-15-2015 12:56 PM
Is it possible to take multiple captures using the self timer? JimS_256 Pentax K-30 & K-50 11 06-27-2014 06:40 PM
Is it Possible to use an AF lens on an MF body? Photo_Man_Dan Pentax Film SLR Discussion 11 04-27-2012 04:54 AM
Is it possible to improve AF with screw driven lenses? button Pentax SLR Lens Discussion 5 12-18-2007 06:47 PM
All times are GMT -7. The time now is 12:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
