07-06-2015, 03:56 PM   #16
crewl1's Avatar
Button press hold by Diy contraption is the only way. Continuous shutter will take the shot each time a critter (or leaf, etc) is in focus. If they stay in focus range the camera will keep shooting
---------- Post added 07-06-15 at 03:58 PM ----------
Yeah, that's the stuff.
Still with the interval problem though. Need the button pressed on a timer somehow. (Somebody must have invented a mechanical cable release intervalometer at some point.)
The continuous shutter negates need for interval mode. With a wired release you press the button and slide the lock. Same as holding the shutter button down.
07-06-2015, 04:38 PM   #17
QuoteOriginally posted by crewl1 Quote
Yeah, I know that, but what if you want interval? (i.e. so it doesn't go crazy shooting a creature hanging out for a long time -- only one shot per 30 seconds or something) Then you need something that will press and hold, release, press and hold, release...
07-06-2015, 06:42 PM   #18
crewl1's Avatar
Oh the critters I was trying to get (hummingbirds) didn't hang out that much.
I was grateful to get any shot quite honestly.
I guess you could use continuous-slow setting, or in your case then why bother with CIF?
If you have regular visitors then just take a shot every 15 seconds and throw away the empties/fuzzies.
07-07-2015, 09:04 AM   #19
Yes, but it only affects actual bulb mode so doesn't help you "hold down the shutter" in other modes even though you are using the so-called "bulb" setting on your wired switch to do continuous shooting.
I will have to test this out.
07-07-2015, 09:13 AM   #20
CIF in bulb mode simply "hangs" the camera (K-3)!
Another undocumented feature!
07-07-2015, 09:31 AM   #21
The above is with the shutter release button...when used with an IR remote (dSLR Remote app), CIF does not work at all (K-3) regardless of the exposure or remote drive mode.
07-07-2015, 09:35 AM   #22
Yes, that works quite nicely. Put the drive mode on continuous shooting, lock the shutter on the remote and walk away. One thing I did notice is that the camera seems to miss a lot of shots.
button, camera, catch, dslr, focus, interval, lens, photography, port, rubber, shutter
Catch in Focus dcpropilot Pentax K-3 17 5 Days Ago 09:13 AM
645Z - Catch-in-focus? iCrop Pentax Medium Format 13 07-03-2015 10:48 AM
catch in focus Ken Glasson Troubleshooting and Beginner Help 11 12-06-2014 11:31 AM
Catch in Focus, Wingincamera Pentax K-5 7 03-21-2014 11:19 AM
Catch In Focus Neville Troubleshooting and Beginner Help 18 02-12-2014 07:22 PM
All times are GMT -7. The time now is 09:49 PM. | See also: NikonForums.com, part of our network of photo forums!
