Originally posted by sharpshoota One question is the focal length for the zoom on the flash. I'm mostly using the FA limited primes so I'm not sure what to plug in here.
I may be completely misunderstanding the question, but if you put the flash zoom mode to 'Auto' The camera will set the flash zoom to match the lens focal length for you:
e.g. with a zoom lens fitted, the flash will change its zoom setting as you zoom the lens (the metering timer on the camera needs to be active i.e. half press on the shutter release button).
dave
