06-14-2008, 10:51 AM   #1
Ari's Avatar
Please Help!!!
Hi All:
It's been a while since I've posted on the forum, but I need help bad I just inherited a k10d from my brother and I am having some major issues. I keep getting an error "the image is not stored". This seemed to happen only when I used the flash (now it happens without the flash) then only every other time I turned the camera on (now it happens sometimes, sometimes it doesn't). Now it seems to happen intermittently. I tried it with two cards - one generic, one pqi. I read this may be a problem with the sd card slot. Has anyone else had this problem and solved it without an expensive trip to a Pentax repair location?
Thanks in advance for any help-
06-14-2008, 10:55 AM   #2
Tom S.'s Avatar
Just a shot in the dark (sorry for the bad pun!), but did you try formatting the SD card with the camera before taking any pictures?
06-14-2008, 10:58 AM   #3
Ari
Ari's Avatar
Hi Tom-yes-it doesn't seem to help
06-14-2008, 11:44 AM   #4
Big Dave's Avatar
Ari,
When you pull the card and look at the contacts, do you see any residue on the contacts? Think that the contacks in the camera may be dirty or slightly oxidized. With the battery removed you could put a little electical contact cleaner on the card contacts and the insert it a few times to clean the camera contacts. Let it dry out before installing the battery for testing.
Dave
06-14-2008, 12:50 PM   #5
Ari
Ari's Avatar
Thanks Big Dave! I was looking around, it seems that there are a few sites that recommend cleaning the contacts in the sd card slot. The kits don't seem too expensive, but I think I may try using contact cleaner. As a note, I read that the current firmware I had (1.2) didn't support 4gb cards. I'm not sure if that's true or not, since I didn't see anything about larger card support in the firmware release notes. I updated to 1.3 anyway. We'll see if that helps
Miss this forum! I have a lot of (unexpected) free time on my hands; looking forward to getting back to reading and posting here!
06-14-2008, 10:57 PM   #6
cupic's Avatar
I still have the original firmware 1.10 and I have a 4gb SDHC card no problemo
cheers
camera, dslr, flash, help, photography
All times are GMT -7. The time now is 09:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
