06-14-2008, 12:26 PM   #1
Flash Question - Turning Off Flash Quickly For a Shot
Just got a Metz 48 AF-1 for my K10D and I've started playing around with it. Love the flash. I've been having lots of fun playing around with it and learning how to use it. The added flexibility of a bounce flash is awesome.
I have a noobie question. When I have my flash attached, what's the proper way of quickly turning off the flash for the next shot? I'm assuming that I just manually turn off the power on my flash or is there a camera setting or button on the K10D?
Sorry for the noobie question but I came from a point and shoot camera before my K10D and there was a dedicated flash button for controlling the flash.
06-15-2008, 09:23 AM   #2
Hi sweetpapa
Re your question:
Assuming I've read this scenario correctly, having taken the first photo using an external flashgun, you wish to employ natural light in the next shot. Should that be the case, simply switch-off the flashgun ! If you don't intend taking further photos with the flash in the foreseeable future, I've always understood it was good practice to fully discharge the flashgun (usually by pressing the test button) immediately before turning it off. If I recall correctly, it's not a wise idea to leave any flashgun in a fully charged-up state before switching it off, because the internal circuitry will still contain a very high voltage, unless you discharge the device ! Hope this info helps somewhat ?
Best regards
Richard
06-15-2008, 11:03 AM   #3
Depends if what lighting conditions I'm in. I enjoy the SB mode on my 540 flash (focus assist only). Turning it off through the switch is very convenient too though.
QuoteOriginally posted by Confused Quote
Best regards
Richard
Can anyone confirm? I always figured if the charge could harm the flash unit, they would allow the test button to still function after you turn it off or a discharge mode atleast, but they don't. So I never saw the reason to discharge before switching to "off".
06-15-2008, 11:18 AM   #4
alohadave's Avatar
QuoteOriginally posted by AVANT Quote
If the flash is designed correctly, the circuitry should slowly bleed off the stored voltage in the capacitor when you turn it off. How slowly depends on the design, but I've been shocked by a small flash in a disposable camera after it was stored for a couple months. IIRC, the thing shocked me twice. Of course, if I hadn't taken it apart, it would never have been an issue.
06-15-2008, 11:57 AM   #5
Hi Avant
I think you may have slightly misunderstood the point I was trying to make , when you said:
I always figured if the charge could harm the flash unit, they would allow the test button to still function after you turn it off or a discharge mode at least.
I wasn't actually implying that by failing to discharge the flashgun, you could possibly harm the unit itself. What I meant was that if you accidentally shorted the contacts of an un-discharged flashgun somehow, there might be a small risk that you could receive an electric shock....seriously though, some units contain sufficient electrical charge (via the capacitor) to kill you. Check out the link below:
https://www.pentaxforums.com/forums/268670-post40.html
Remember folks, please don't try this experiment at home !
Best regards
Richard
06-16-2008, 12:04 AM   #6
Hi sweetpapa
Re your question:
Best regards
Richard
Thanks, that's exactly what I was trying to confirm.
button, camera, dslr, flash, flash question, k10d, noobie, photography, question, shot
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
Shot random people outside with a flash? Zakovva Photographic Technique 21 09-02-2009 02:25 PM
Turning off flash on K200D luzianne Pentax DSLR Discussion 5 07-05-2008 09:45 PM
Maria, Portrait... beautiful although shot with builtin flash Alcazar Post Your Photos! 0 04-20-2008 04:15 PM
2 flash product shot Tyler Post Your Photos! 6 03-10-2008 12:20 PM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
