07-21-2015, 06:59 AM   #1
Bunch's Avatar
Low Light Noise
Does reducing the jpeg resolution in the K-3 when shooting in a low light/high ISO situation make for an image with less overall noise? If so, is that offset by the the resolution downgrade? For the purpose of this question we are talking jpegs. I know a raw image with proper post processing will produce the cleanest image.
07-21-2015, 08:54 AM   #2
Reducing resolution is not a good way to cure a noisy image. The reduced resolution image will appear to have less noise if you zoom in at 1:1. If you compare reduced and full resolution versions on the same size screen or print then you probably won't notice a difference in the noise level.
My preference is to always have the full resolution in case I want a large print or crop. I usually use raw DNG and wait until I'm home at my desktop PC with Lightroom. If I expect to view images before getting home, though, I use DNG + low res JPG. I might look at the JPG files in the field but I discard them when I get home, keeping only the DNG.
YMMV, though. For comparison purposes I suggest putting your camera on a tripod and take test photos of the same scene, only changing the resolution setting between photos. Then view or print the photos however they are going to be used to see the differences.
07-21-2015, 10:20 AM   #3
If you are willing to give up some resolution anyway, you may also want to try experimenting with the High ISO noise reduction setting on the K-3. I'm not familiar with the menus on the K-3 but it is probably under one of the record mode menus.
07-21-2015, 10:45 AM   #4
QuoteOriginally posted by reduno Quote
The in-camera NR options wash away details, but indeed they also do a fairly good job of dealing with noise.
QuoteOriginally posted by Bunch Quote
RAW is always going to be the way to go in low light. You just can't beat it. The next best thing, IMO, is to turn off in-camera NR and post-process your JPEGs with good NR software like Topaz DeNoise, etc.
camera, dslr, image, noise, photography, resolution
K-30 to K-3 for low light action and shutter noise...worth the jump? Masta' C Pentax DSLR Discussion 23 08-07-2014 05:30 AM
DXO Low-Light ISO rating - what does it mean? wildman General Photography 28 08-07-2014 03:24 AM
Upgrade k3 vs k5 II? (low light considerations, features, expense) Rice Pentax DSLR Discussion 5 06-14-2014 03:40 PM
Noise and Low Light imagery sany Photographic Technique 8 07-22-2011 04:14 PM
Low light and noise Substitute Photographic Technique 11 11-09-2007 10:31 AM
All times are GMT -7. The time now is 06:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
