Originally posted by slip anyone ever get situations where your DSLR can't handle a lighting situation?
My K5iis can't handle this stage lighting as well as my old K10D could. On this shot (example) I tried everything... different metering...even spot metering...-1 stop... and nothing could give me a good shot in this lighting situation. Anyone have the same problem? Usually spot metering would do it but not in this lighting. any thoughts?
thanks, randy
Classic example of why you should use Manual exposure. The meter exposed for the curtains so the bright portions were overexposed.
Instant review and the histogram are the modern day Polaroid test exposure and are fast and easy to use. Unless your graduate was the first, make a guesstimate exposure, take a shot and adjust.
You're shutter speed should be faster, 1/50, even with SR is unnecessarily slow. ISO is unnecessarily high at 5000. You've a fast lens at 2.8. The grin & grin is all in one plane and fairly static so focusing isn't a problem and you don't need a lot of DoF, f2.8 is okay. So start with a guesstimate of 1/125 and ISO 1600 and see what happens. Then simply increase ISO as needed.
I shoot in theaters a lot and manual exposure is the only way. Most stages are EV 7 or 8 (assuming ISO 100). To stop motion of dancers, I start at 2.8, 1/320 and 1600. You didn't need to stop a dancer in mid air so 2.8, 1/160 or 1/125 and 1600 would have probably been okay.
I have a pair of K5IIS bodies in my bag and K5 as a spare and I've no idea if the meters work, I don't use them. It just isn't that hard to learn manual exposure and I guarantee you'll like your work better. Here's a good, free explanation
The Ultimate Exposure Computer
Everything on my web sites was done with manual exposure. I still occasionally use a handheld incident meter and a flash meter for studio setups but mostly can make a pretty good guess and simply adjust. Manual exposure gives you full control, auto modes, not so much.
P.S. - Found an example from 2010. Manual exposure, K20 & 50-135: f2.8. 1/160 and ISO 1600. Didn't get my K5-s until 2011.
