09-24-2015, 04:25 PM   #16
Thanks but I don't have an RF-603. Anyway, I can still use this flash on my K-5II. Maybe yongnou will come out with something different. If not the 460 would be my option.
09-24-2015, 07:11 PM   #17
Mikesul's Avatar
I have used a cheap Cowboy studio trigger. It works fine but is a bit unwieldy.
10-26-2015, 03:57 AM   #18
Has anyone encountered a yongnou 660? I saw it in hkyongnou.com. I'm curious if it will fit the k-3II.
01-12-2016, 04:36 AM   #19
Hello.
I'm loking for a flash fully compatible with my K3-II. I've asked on yongnuo for yongnuo 560 IV, and they say that iit's compatible. In that post says that there are some diferences between K3 and K3 II shoes. Is that correct?
What could be a flash max 150$, to a non professional photografer, only to take some pictures at home, with low light?
I'll apreciate your contributes
Best regards
01-12-2016, 10:16 AM   #20
QuoteOriginally posted by luismpg Quote
Hello.
Best regards
Here's a slightly outdated but still extremely useful site for info on Pentax flashes. The Definitive Guide - Pentax P-TTL Flash Comparison He hasn't updated it recently but the information is still true, it just doesn't include the latest models.
For a non professional I would definitely recommend an P- TTL flash as your first flash. (watch out for TTL, which is an older standard from film days and is incomatible.) It requires almost no thought and will pretty much just work the first time. A manual flash will require you to change flash power as you change distance to your subject or move to different areas, and is best for when you can take a shot and make an adjustment if it didn't come out right. (Your budget allows for a decent TTL flash as well.)
For compatibility I'd recommend an official Pentax flash or any of the recent Metz flashes for Pentax since most of them can have their firmware updated easily as new cameras come out. I have the Metz 50 AF-1 and it works great on my K-3. My suggestion is to get one with a swivel head so you can bounce flash to the side or from behind as well, but tilt only would work fine for direct flash or bounced from the ceiling. If all you need is a simple flash similar to the pop up flash on previous DSLR's, you might also like the 26 AF-1 (link).
Sigma models also work well, but you should check to make sure they're compatible with the K-3 II (search the forums here). The ST versions are basic, and the Super version have a few more features.
If you want to start out cheap to see how it works for you, here's a $70 Metz 36 AF-4 with an off camera extension on eBay.
Keep an eye out on eBay for deals too. I got my Metz 50 AF-1 for $50, and it routinely sells for more than $150.
eBay Metz flash search
eBay Sigma flash search
eBay Pentax flash search
01-12-2016, 10:24 AM   #21
OP - If you just need a basic manual flash (no need high-speed sync) - I would highly recommend Neewer TT660 II. I just picked one up for about $44, it fits K3II just fine and works very well:
Neewer 2 4G Wireless Speedlite Flash TT660 II for Nikon Canon Pentax Em 01 | eBay
01-13-2016, 11:17 AM   #22
QuoteOriginally posted by TheOneAndOnlyJH Quote
Thans for your explanation. Actually after a long study of YN-560 IV, realize that doesn't have P-TTL.
Regarding Yongnuo, there isn't any model for pentax with TTL. So I've decided to not buy this brand. I've decidel to look for a Metz Flash (52 AF 1) or a Cactus RF60. I'll decide for one of this units flash
Best regards. And thanks
---------- Post added 01-13-16 at 11:18 AM ----------
QuoteOriginally posted by genesmasher Quote
Thanks, I've seen this model i'ts a good choice, and TT 850 is too.
regards
01-13-2016, 11:21 AM   #23
Pentax compatibility METZ
Just to share with all pentaxian members, April 2015 Metz compatibility cameras
File Type: pdf Metz_camera_compatibility_April_2015_Pentax.pdf (334.1 KB, 85 views)
01-13-2016, 03:03 PM   #24
regards
FYI, the TT 660 and TT 850 are also manual flashes and don't support P-TTL. You're best sticking to Pentax, Metz, or Sigma for P-TTL support. There are others, but you may have compatibility issues with latest cameras if they don't have updated firmware support.
In general,
If a flash is compatible with either Canon (e-TTL) or Nikon (i-TTL) then you can bet it is not compatible with Pentax P-TTL. (Some flash triggers might be, but I haven't seen a flash that supports multiple brands of TTL.)
If a flash advertises compatibility with "Canon, Nikon, Samsung, Pentax, Olympus"... or any long list of camera manufacturers it is probably a full manual flash and does NOT have TTL capabilities.
Some older flashes ( even back from the 1980's) have AUTO mode (also called thyristor or auto-thyristor) in which the flash has a sensor and determines the correct level of flash without communicating with the cameram, so you have to input your set aperature / ISO so the flash knows what you want. (Some people claim these can be more reliable than even the official Pentax P-TTL flashes.) These are triggered by the center pin only, but some old ones have a high circuit voltage that could damage digital cameras, so I can't give you too much advice about them. Check this thread for some more info on these (about page 4).
As a matter of fact, you should read through that thread anyway since it seems to be right in line with what you're asking about.
Best of luck as you enter the crazy complicated world of flash!
01-14-2016, 03:42 PM   #25
Ron_Man's Avatar
On the topic of replacement would anyone recommend the Cactus RF60?
01-14-2016, 04:11 PM   #26
clackers's Avatar
QuoteOriginally posted by Ron_Man Quote
It looks to be a fine flash - @ClassA has used and reviewed them.
af-1, camera, discovery, dslr, ebay, flash, ii, k3ii, metz, neewer, pentax, pentax k3ii, pentax k3ii yangnuo, photography, search, share, sigma, ttl, yangnuo yn560-iii, yn560-iii
Triggering (optically) an AF 540 FGZ + YN560 III EarlVonTapia Flashes, Lighting, and Studio 9 02-13-2015 04:38 PM
Controlling YN560 III with YN560 IV or YN560 TX T Evergreen Flashes, Lighting, and Studio 9 02-10-2015 08:52 AM
YN560 III test button defective on ALL of them? peterh337 Flashes, Lighting, and Studio 10 10-18-2014 02:12 AM
Yongnuo YN560-III Flash chart question Driline Flashes, Lighting, and Studio 10 08-30-2014 08:59 AM
YONGNUO YN560 III as slave to K20D / Metz 58AF2 K20DPete Flashes, Lighting, and Studio 5 04-11-2014 05:35 AM
All times are GMT -7. The time now is 02:10 PM. | See also: NikonForums.com, part of our network of photo forums!
