02-16-2019, 03:48 PM   #31
QuoteOriginally posted by luismpg Quote
Thans for your explanation. Actually after a long study of YN-560 IV, realize that doesn't have P-TTL.
Regarding Yongnuo, there isn't any model for pentax with TTL. So I've decided to not buy this brand. I've decidel to look for a Metz Flash (52 AF 1) or a Cactus RF60. I'll decide for one of this units flash
Best regards. And thanks
---------- Post added 01-13-16 at 11:18 AM ----------
Thanks, I've seen this model i'ts a good choice, and TT 850 is too.
regards
You'll need a flash extension mount when using Yongnou 560 flash models on the k-3ii. Firstly the k-3ii prism size increased to accommodate the GPS. Secondly all Yongnou flashes have a sort of extended body towards the base making it impossible to mount the flash on the k-3ii. The extension mounts are available and Pentax has one. I have one and I use it when using my 560ii on my k-3ii.
As for PTTL, you can buy the 565EX. Yongnou made it for Pentax cameras. You won't have issues mounting it on the k-3ii. But, I still recommend using the extension mount as the clearance between the flash and body is still minimal. A slight press will still push the flash towards the prism. And, I wouldn't want to scratch my camera. 565Ex costs a little more but it's a gray flash for its features and its price.
06-22-2020, 02:59 PM   #32
12345's Avatar
Sorry to resurrect an old post, but I just realized that my new K-3II won't mount any of my YN-560III or IV flashes... Has anyone found a cheap adapter solution, or am I better off getting another flash, like the YN-585 EX? It doesn't look like the 585 can work as a master for radio control, so that's a bit of a bummer. Should I invest in a radio controller instead? I'm open to any ideas, cause I have a big photoshoot coming up in a bit over a month, and I need to get my ducks in a row before then.
06-22-2020, 03:00 PM   #33
12345's Avatar
QuoteOriginally posted by 12345 Quote
Any links to actual solutions where I can buy it would be appreciated. I've seen various "adapters" mentioned in this thread, but I don't know exactly what is being referred to, or where to buy it. Thanks in advance!
06-23-2020, 04:01 AM   #34
This is what I bought so that I could use my old Yongnou 565II. It's a Pentax original extension and it's a little pricey compared to generic the ones. I believe generic extensions can be bought on Ebay. I just don't know which brands are compatible with Pentax. I would recommend the 585EX. I have one and it fits the k-3II well. As I've stated, it's still best to use and extension mount as the clearance on the prism is quite close. Good luck on your choice.
06-23-2020, 11:27 AM   #35
Otis Memorial Pentaxian
No problem bumping this thread to life again. I was unaware that the fit issue extended to the IV version when paired with the K-3II. That sucks. I have the YN560 III and it is very tight on my K-3 and while the IV will definitely fit my camera, the K-3II prism profile is just a bit steeper.
Radio wireless might be a good solution. Adorama is offering a close-out on the RF-603N II as two unit kit (includes a cable that you can't use) for $32 USD. The Nikon version will wake up on shutter half-press and provides basic remote firing to all your YN560 flashes and a pass-through shoe. I bought the kit to use for radio wireless shutter release.* That said, I also have a YN560-TXII that would allow one full control your speedlights from the camera that is available for $41 USD. Again, the Nikon version will wake up on half-press. The TXII on hot shoe with the flash on bracket might work nicely.
Sadly, no Yongnuo controller accepts PC for sync input.
https://www.adorama.com/ynrf603iin1.html
https://www.adorama.com/yn560txnii.html
* Requires a separate male-male 2.5mm cable for remote shutter, but those are cheap.
af-1, camera, discovery, dslr, ebay, flash, ii, k3ii, metz, neewer, pentax, pentax k3ii, pentax k3ii yangnuo, photography, search, share, sigma, ttl, yangnuo yn560-iii, yn560-iii
Triggering (optically) an AF 540 FGZ + YN560 III EarlVonTapia Flashes, Lighting, and Studio 9 02-13-2015 04:38 PM
Controlling YN560 III with YN560 IV or YN560 TX T Evergreen Flashes, Lighting, and Studio 9 02-10-2015 08:52 AM
YN560 III test button defective on ALL of them? peterh337 Flashes, Lighting, and Studio 10 10-18-2014 02:12 AM
Yongnuo YN560-III Flash chart question Driline Flashes, Lighting, and Studio 10 08-30-2014 08:59 AM
YONGNUO YN560 III as slave to K20D / Metz 58AF2 K20DPete Flashes, Lighting, and Studio 5 04-11-2014 05:35 AM
All times are GMT -7. The time now is 02:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
