Show Printable Version 4 Likes Search this Thread
08-12-2015, 08:36 AM   #1
Is TAV mode Pentax-only?
I have been looking at the APS / micro-4/3 cameras lately. I decided to not bother because the loss of quality / usability was too big for me and they need to be carried around in the same way (waist pack, backpack, etc) as my K3 so there is little practical benefit.
But I also noticed none had the TAV mode, which I use nearly all the time.
Did Pentax manage to patent it?
08-12-2015, 08:43 AM   #2
I think you can get equivalent or close functionality on some other brands/models, but it is a more convoluted path, not just a setting on the dial as with Pentax. I think TAV with EV comp ability will be hard to find on other cameras, but maybe some of them have it now?
08-12-2015, 08:48 AM   #3
boriscleto's Avatar
Whenever I talk about TAv to Canikon users they just say "That's just manual mode with auto-iso".
08-12-2015, 08:54 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by boriscleto Quote
That is my understanding as well. The nice thing about Pentax is that the TAv behavior is always available as a set mode while allowing set ISO for all other modes, particularly M.
08-12-2015, 09:06 AM   #5
wtlwdwgn's Avatar
The other brands make you go into the custom settings to setup auto ISO while Pentax provides it on the mode dial. Unfortunately though it doesn't work with older manual lenses without an A setting on the f stop ring.
08-12-2015, 09:30 AM   #6
aleonx3's Avatar
I don't think it is the same, TAv mode support EV compensation whereas M with auto-ISO does not.... at least that's my understanding after trying it on Nikon D750 (I could be wrong though because I didn't spend a lot of time on it). Similarly, on k-01, it does not have TAv mode but M with auto-ISO..
I also think that it is difficult to implement TAv mode without front-and-rear dial, which Canon DSLR model does not have.
08-12-2015, 09:52 AM   #7
TER-OR's Avatar
I like TAv - and M - and being able to switch between them (without menu diving) when you want control over all parameters. Most of the time TAv is what I use, I want to control the primary variables and let the camera deal with the rest.
08-12-2015, 09:52 AM   #8
boriscleto's Avatar
QuoteOriginally posted by aleonx3 Quote
All true. But Canikon users don't see it that way...
08-12-2015, 10:48 AM   #9
Bingo! I use both TAv and manual extensively and the idea of having to change from Auto-Iso to set ISO is a non-starter. I normally shoot TAv but If I'm doing something at sunset or later I like to switch to manual mode where I can under or over expose easily using the dials/roller-wheels.
08-12-2015, 10:50 AM - 1 Like   #10
aleonx3's Avatar
Doesn't bother me whatever Canikon users think or do... not my job to show or convince them.
08-12-2015, 11:53 AM   #11
CarlJF's Avatar
QuoteOriginally posted by TedW Quote
For Canikon users, features they don't have are usually considered useless...until they have it! Most funny I heard from them is that IBIS is useless but at the same time will spend extra money to get the stabilized version of their lenses...
08-12-2015, 11:55 AM   #12
Fogel70's Avatar
Some Nikon bodies with auto-ISO have EV comp. They have had for some years and I believe D750 has it too. And nowadays it pretty easy to switch between auto/manual ISO on Nikon, just hold ISO-button and turn front wheel.
Nikon have some nice features in auto ISO I would like on my Pentax, FI that you can set slowest shutter speed that auto ISO use (or auto like on Pentax), and when adjusting ISO in auto ISO you adjust the lowest ISO in the auto ISO range instead of going back to manual ISO.
The auto-ISO functionality have not changed much on Pentax bodies since K-7, but I really hope Ricoh understand that they could make the cameras even more flexible with a few small changes on auto-ISO.
- User defined slowest shutter speed, maybe an option for TAv mode. So that you either set an absolute shutter speed, or the lowest shutter speed you want to use so the camera can set faster shutter speed if ISO have reached the lowest ISO and the image risk being overexposed.
- Possibility yo change lower and upper limit of auto-ISO without having to enter menus.
- Wider range of "auto ISO parameters" instead of slow, normal and fast it could be +-4 stops of nominal shutter speed so can make full use of image stabilization. Or maybe even an auto setting where camera adapt slowest shutter speed depending on focal length and how much camera shake there is.
08-12-2015, 12:03 PM   #13
QuoteOriginally posted by peterh337 Quote
I think the TAv mode dial setting is something only available on Pentax bodies, but it is functionally equivalent to M mode with auto ISO, so most other cameras do support it that way.
08-12-2015, 02:17 PM - 2 Likes   #14
The Q7 does not have a TAv setting on its mode dial. TAv mode is enabled just as Adam described. Go to Manual mode and enable Auto ISO. The TAv mode icon appears in the upper left hand corner of the display.
08-12-2015, 02:26 PM   #15
boriscleto's Avatar
QuoteOriginally posted by 6BQ5 Quote
And the K-01 works the same way. Unfortunately the K-30/50/500 also work the same way even though they have TAv on the mode dial...
camera, cameras, dslr, mode, photography, tav, tav mode
TAV Mode Query rayallen Pentax K-3 & K-3 II 9 07-01-2015 10:18 PM
Manual mode on my K10D is acting like TAv mode Love my K10D Visitors' Center 9 11-06-2013 11:44 AM
Is it possible to use manual flash in TAv mode? ismaelg Pentax DSLR Discussion 3 07-09-2013 11:52 AM
Is Av Shift and/or Tv Shift in TAv Mode possible. robert_s Pentax K-5 & K-5 II 3 09-30-2011 09:03 AM
TAV mode is so cool!!! regken Pentax DSLR Discussion 3 04-11-2007 08:12 AM
All times are GMT -7. The time now is 08:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
