Originally posted by UncleVanya Any other words of wisdom are welcomed.
Hi Uncle
I think 2GB is maximum.
To see version, switch OFF, press and hold "Info" + "AE-L" and switch on.
Do the following at your own risk:
iF you want debug mode, within 5 seconds of the above switch on sequence,
Press "menu", "menu", "info"
Then you can change "Debug" from "dis" to "EN" (enabled)
Switch off.
At next switch on, > "menu" click across to "setup" pane.
Some debug items are now listed at end of the "setup" items.
That gives the ability to trim the focus point if required.
To disable the debug facility
Then you can change "Debug" from "EN" to "dis" (disabled)
Another useful test of the ist ds is a button test, because they can go intermittent.
Within 5 seconds of the above switch on sequence,
Then you can select "Switch Test"
All the buttons are listed on the rear lcd and you can test each one.
