02-07-2007, 06:25 AM   #1
kshapero's Avatar
K1000 and the 43mm
When I use the 43mm lens with the K1000D the aperture ring on the lens, it is kaput. It does nothing. Am I confused? Is this how it is with all pentax lens that have aperture rings (as in all non D lens)? Same with the K10?
02-07-2007, 06:40 AM   #2
jeffkrol's Avatar
K1000 or K100D? 43 is a D-FA lens. Should be fine on all bodies
My Favorite Lens
Everything from the "K" lens onward will fit on any K-mount camera, from the KX and K2 to the ZX-5n and MZ-S, and including the K-1000 and all the M-series and A-series cameras. There are no significant incompatibility issues apart from the program-mode contacts present in the A-series onwards, and of course you need both an autofocus camera and and autofocus lens to get autofocus capability
02-07-2007, 06:44 AM   #3
kshapero's Avatar
I mean a K100D
Sorry for old habits. My question pertains to the K100D!!
02-07-2007, 06:50 AM   #4
u need to enable "use A ring" in the menue then press the ae-l button to stop down to whatever aperture setting u have set.. if u dont press the button the camera will use the widest aperture..
this applies to none A lens only.. or an A lens if u dont use the A position..
trog
02-07-2007, 06:55 AM   #5
Hi and welcome to the forum. I don't have the K100D, I have the DS but I'm pretty sure the menu choices are pretty similar. To make the aperture ring on you lens work you have to go into the Custom menu and set "Using Aperture Ring" to option 2 "permitted" Then you can use the aperture ring manually. Alternatively you can leave the aperture ring on the "A" setting, set your mode dial to Av and change the aperture with the thumbwheel in the back of the camera. BTW, the second way is much easier!
NaCl(hope that helps)H2O +
43mm, aperture, camera, dslr, lens, photography
Where is this K1000 from? alnegri Troubleshooting and Beginner Help 3 05-04-2010 10:32 AM
How much might I be able to get for my K1000? beep41 Pentax Film SLR Discussion 6 03-19-2010 09:08 AM
For Sale - Sold: K1000 bodies, ME Super Body, Damaged K1000 SE Body Rustyoldbug Sold Items 7 11-11-2009 08:48 AM
For Sale - Sold: 43mm Ltd + K1000 with 50mm + MZ-6 body + CS-205 + FA 18-35 CapitaineAbitibi Sold Items 5 09-10-2008 05:00 AM
For Sale - Sold: 43mm Ltd, 77mm Ltd, K1000+50mm + other stuff CapitaineAbitibi Sold Items 2 08-19-2008 11:07 PM
All times are GMT -7. The time now is 08:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
