09-08-2015, 01:16 PM   #1
Bromberger's Avatar
I think there should be more Hyper in the Green Button
Hi there,
i'm using hypermanual, meaning the manual mode in combination with the green button.
One can choose from 3 ways how the green button will set exposure: Program line, time shift, aperture shift.
I have it set to time shift, because most of the time i choose an aperture for the depth of field that i want, then push the green button to have the camera set the time automatically. Sometimes, i would like to have it set to aperture shift, but i'm too lazy to go into the menu and change it.
All nice and well. But then i'm thinking: Why do i have to choose between time shift and aperture shift anyway?
Wouldn't it be cool if the green button would switch to time shift as soon as i use the aperture wheel, and then switch to aperture shift when i use the time wheel?
I mean, that's sort of what's happening in Hyperprogram, and what makes Hyperprogram cool to begin with, right? (There, when i use the time wheel, the camera switches to Tv mode; when i use the aperture wheel, it switches to Av mode).
I think that would be a more thought out version of Hypermanual.
Do you agree? Am i missing something?
Greetings, Bromberger
Edit: Actually i realised you could do the same thing for the iso button: Press the iso button, and while holding it, press the green button - the camera would set the iso according to the time and aperture you have already set with the wheels. I would love that.
09-08-2015, 01:20 PM   #2
enoeske's Avatar
QuoteOriginally posted by Bromberger Quote
Hi there,
I think manual mode should be just that; manual. I'd rather not muck it up with some auto whatnots. When I want intervention from the camera, I'll use one of the plethora of semi auto modes.
09-08-2015, 01:33 PM   #3
Bromberger's Avatar
QuoteOriginally posted by enoeske Quote
Your way of working is fine, of course!
However, this thread is not about pro and contra of the green button.
09-08-2015, 01:52 PM - 1 Like   #4
Here's a tip you might enjoy: when in manual mode, press the exposure lock button and then spin either wheel. The camera will maintain equivalent exposure but trade aperture and shutterspeed against each other.
Regards,
--Anders.
09-08-2015, 01:57 PM   #5
Otis Memorial Pentaxian
I thought Hyper-Manual was when you* Use AE-Lock in M mode. I believe it operates as you describe and will save wear and tear on the green button. Edit: (Assuming your camera has an AE-L button and that it has not been reconfigured to do something else.)
* My mistake. The terms Hyper-program and Hyper-manual get thrown around a lot and I have heard it described both ways
09-08-2015, 02:04 PM   #6
enoeske's Avatar
You are looking for an easy way to go from Av to Tv "Wouldn't it be cool if the green button would switch to time shift as soon as i use the aperture wheel, and then switch to aperture shift when i use the time wheel?" I don't understand how the green button comes into play here. You want Av when you move the Av wheel and Tv when you move the Tv wheel. That is, by definition, hyper-program mode. You don't even describe pressing the green button at any point in that idea. So, what does this have to do with Manual mode and why do you want to muck it up?
09-08-2015, 02:13 PM   #7
Fogel70's Avatar
I prefer it they way it is now, but it would not hurt to be able to change the green button function without having to go to custom functions in the menus.
I use TV-shift for green button in Hyper-manual 99% of the times, so I don't want the camera to automatically change to Av-shift.
In manual mode it might even be hard to remember which you changed last (shutter speed or aperture), so you might get a surprise when you press the green button, if it would change automatically.
09-08-2015, 03:27 PM   #8
Imp
Imp's Avatar
Except i use it for back button focus...
09-08-2015, 05:59 PM   #9
QuoteOriginally posted by Imp Quote
Trade one element of functionality for another, I guess. One thing this thread lacks is a clear understanding of what cameras are under discussion. I guess you are shooting with a model having a duel-purposed AE-L button (K-30?). According to user profile, the OP owns both a K-3 and K10D. The options are a little different depending on what buttons are present and what configuration options have been exercised.
09-09-2015, 03:00 AM   #10
Imp
Imp's Avatar
Ah, i didn't realize there was a difference, and yes, I use a K-30.
09-09-2015, 05:20 AM   #11
You can use Av/Tv mode. Back wheel is for AV, and front one for Tv regulation. Keep constans ISO (ex. 200),
09-09-2015, 11:13 AM   #12
Although I haven't used one, I believe that the Z-1 and Z-1p SLRs used to work the way you describe - ie. whichever dial you turned last, that became the 'primary', value, and pressing the green button shifted the other value. This is different to how it works on the twin-dial Pentax DSLRs, as you say, where the choice of 'primary' value is set via menus.
Personally, I agree that this would be a good way to do things, and have often wondered why Pentax changed this behaviour. It could at least be offered as a fourth option in the menus. The hyper manual mode is one thing which for me sets Pentax cameras apart from any other, and I stay in manual mode almost all the time because of the speed and flexibility it offers. However, I think having your suggestion as an option could make it even better.
The OP's suggestion really doesn't 'muck up' the manual mode. He's just suggesting a variation on the behaviour which is already present. If you want to control both exposure values totally manually, you can - just don't press the green button.
aperture, button, camera, dslr, hyperprogram, mode, photography, shift, switch, switches, time, wheel
The manual should have more in it. fb_penpho Pentax K-S1 & K-S2 12 06-25-2015 07:24 AM
I've never used the green button until now. larryinlc Pentax K-01 24 12-19-2012 02:20 PM
Why the green button in manual mode? geekette Pentax DSLR Discussion 5 05-05-2011 12:01 PM
The 60-250 won't be here in time, what should I do? applejax Pentax SLR Lens Discussion 15 05-18-2008 05:00 AM
how much play should there be in the lens? slip Pentax DSLR Discussion 3 12-04-2006 09:32 AM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
