Originally posted by splash_fr In wanted to use the off-center points for portraits. With a 135/2 using center point and recompose is not accurate enough.
Thanks for the interesting discussion,
gerd.
Not quite to the point, but you might consider swapping out your focusing screen to an S-type or other replacement with greater DOF differentiation. I found my 'hit' rate improved probably 5-fold on older manual glass once I replaced mine. I usually have focus confirmation switched *off*, FWIW.
(*edit - sorry, wrong quote initially)
