J
Originally posted by UncleVanya DH = Dear Husband I believe.
Darling, domineering, dreadful, duped ..... The possibilities are endless!
Back on topic, I too would avoid taking a new, unfamiliar camera on a special trip. Unless you have a few days before to specifically go out and practise and learn about all the settings and shooting parameters you'd need to use quickly when out on the streets and in changing conditions.
Unless you're worried that you'll need the high ISO, or frames per second performance, of the K50, then I'd stick to the tried and tested camera wise.
Lenses are a different matter, and don't need the same familiarity and learning. In fact those new perspectives from a change of glass can inspire. I'd use the trip as a chance to get that wide to mid zoom or special prime you always knew you needed, and go and see what it can produce!
