Originally posted by MJSfoto1956 IMHO, the two techniques look quite different. I often like to "combine" both techniques in post by shooting three bracketed shots, doing some subtle HDR, then manually blending darker and/or lighter parts of the images to my liking.
Michael
I tried in camera HDR, did not like it all honestly.
I'll use the grad filters next time.
Originally posted by mcgregni Bearing in mind that you must be shooting camera jpegs, then there's no quality loss from using the HDR feature. Do you actually take processing control and edit your images (as intended) with the camera custom controls, or do you just use one pre-set for everything?
If its just simple balancing of darker ground and bright sky, then I think a grad filter would be best. If you are struggling with wide Dynamic Range scenes and want to show status details in shadows while compressing highlights then HDR may be more successful. Really, both are valid and worth a few spots each .....
I set the camera to landscape and up'd the saturation.
that was it.
Originally posted by sholtzma May we ask what computer capacity you have (RAM, hard drive space, processor, etc)? Not all image processing software is equal in its demands.
I'm not sure because it's my brother laptop.
My sunset photos are in, unedited.
You guys are right. Once the sun goes down, everyone leaves, I stayed behind and it was worth it.
In order to get an actual shot of the sun, i'll definitely need a grad filter.
My 2nd fave
My all time fav
Well, I'll check out the specs and see what post processing software I can use.
Thanks for the answers.
