Originally posted by Scorpio71GR I have a K50 and it is a great little camera, however the K-S2 is a much more advanced camera. If this is your only camera the K-S2 will offer you more in the long run.
K-S2 is more or less same electronics as K-S1. I use K-S1 when travel light with limited lens such as DA40,DA21 and K35/3.5.
My main camera is this venerable K-3. Also I use K5 with Katzeye screen for manual lens only, which now is heavely used with about shuttercount of 20.000. Never made any problem.
I actually don't think that K-S1 and K-S2 is so much better than K50. K50, if it can stay healthy, I would at times prefer over K-S1.
K-S2 has better monitor, is WR and has two wheels which I miss on K-S1.
But I will not buy K-S2 because it uses same solenoid like is used in K30 and K50 and starting to fail now in first K-S1 and K-S2 models.
Too sad. Otherwise happily I would exchange K-S1 against K-S2 just for 2 wheels and tilting monitor.
Maybe in RAW I can find more resolution in IQ with K-S1 but in lowlight K50 has advantage. Less noice.
Same I have found with K5II against K3. K3 more resolution but K5II less noice.
Not so easy. But AF of K3 is superior to all.
