10-10-2015, 06:31 PM   #1
When camera is in "AF Active Area Select" how to use ISO, Flash, WB, timer buttons?
When using a Pentax DLSR (K-30 in this case, I assume it is the same for all models) with autofocus set to active area select, the 4 way selector is used to select the specific autofocus point. If I want to maintain the AF selector, but change ISO for instance, how do I do it? Is there anyway to regain or toggle use of these buttons while staying AF-active area select?
10-10-2015, 06:37 PM - 1 Like   #2
jatrax's Avatar
This is different on each model. On the k-5 you hold the 'OK' button in until it beeps and that is the toggle. On the k-3 there is a separate toggle button. On the k-30 i do not know but try holding the OK button in and see if that works.
10-10-2015, 06:37 PM - 1 Like   #3
MadMathMind's Avatar
Hold the OK button until it beeps.
10-10-2015, 07:15 PM   #4
Well that was easy, thanks guys
10-11-2015, 12:56 AM   #5
Culture's Avatar
Having the K-30 myself I hate having to toggle. I am not sure but I think it might be possible to assign the green button to use as ISO in bottom customization.
I could be wrong.
10-12-2015, 06:23 AM   #6
You can assign ISO to the other e-dial in Av and Tv-modes, another alternative is using the Sv mode with program shift assigned to the other dial (this is actually a mode I often use on my K-S2!).
autofocus, camera, dslr, iso, photography, selector
WB is "Cloudy" in camera but is changing in file LowVoltage Pentax K-5 3 02-25-2013 01:11 PM
"How to use Flash" Resources? iocchelli Photographic Technique 3 03-22-2011 10:10 PM
i've actually learned how to use LiveView + contrast AF "properly"... RolloR Pentax DSLR Discussion 27 09-28-2010 08:14 AM
How to ISO in "P" Mode Stratario Pentax DSLR Discussion 6 05-12-2009 05:43 PM
Can some explain "WB when using flash"... dlee Pentax DSLR Discussion 5 03-03-2008 02:58 AM
All times are GMT -7. The time now is 12:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
