11-03-2015, 09:13 PM   #16
UncleVanya's Avatar
Just in case someone else is on the fence the "slightly better sr" may only be an update in name. There are speculations that the change merely reflects a change in testing and certification.
11-03-2015, 10:48 PM   #17
Depends on your point of view. Anecdotally their are personal reports of better sr in the II model.
Make of it what you will.r
11-04-2015, 07:41 AM   #18
UncleVanya's Avatar
QuoteOriginally posted by howieb101 Quote
That's news to me. I had not seen any. If you can point me in the direction of those I would appreciate it. I was under the impression this wasn't really anything other than a paper update in the SR department. I would love to know it was an actual improvement but I imagine it is hard to test methodically.
11-04-2015, 11:06 AM   #19
jatrax's Avatar
Almost impossible I suspect, at least without test gear of some sort. I have k-3 and k-3II and as far as I can tell there is no difference. Not saying there isn't a difference, only that in the real world I cannot see it.
11-04-2015, 11:09 AM   #20
UncleVanya's Avatar
That's sort of what I understood. 1 stop delta may be hard to test using human hands that know which camera they are holding...
10-15-2017, 01:18 PM   #21
mischa72's Avatar
If you want built in GPS. Outside of that, honestly not much. The pixel shift is also new but I have yet to find a use for it. For me, the GPS is completely worth the difference. In fact I traded my 1 year old k-3 in on a k-3II just to have the GPS. YMMV.
Just my curiousity: can you tell how much extra battery power the GPS functionality takes? Easier said: how much more picture can you shoot by turning off GPS?
Best regards,
10-15-2017, 02:11 PM   #22
Paul the Sunman's Avatar
I do not have the K3ii, but I do have the K-1, which also has GPS. I use it all the time and have not noticed any significantly increased battery drainage.
Of course, comparing the K3ii to the K3, the latter has built-in flash, which is likely to draw much more power than GPS if you're using it.
10-15-2017, 03:15 PM   #23
Seeker of Knowledge
aslyfox's Avatar
I know that the OP has chosen a K 3
this post is for others who may be considering choosing between a K 3 and K 3 II
what would you use more
fill in flash or any flash or gps tracking?
as Adam said, you can get the accessory GPS unit ( which will prevent use of a flash when in use ) and have GPS capability with the K 3
otherwise, I don't see any advantage of the K 3 II over the K 3 for me and I would put any money saved towards a lens. IMHO, YMMV
Pentax K-3 II vs. Pentax K-3 vs. Pentax K-7 - Pentax Camera Comparison - PentaxForums.com
10-16-2017, 12:06 AM   #24
mischa72's Avatar
I want to step up from my K5 to the K3II because of the better low-light performance, faster focus and higher shooting speed (raw fps). When I need a flash I'll take my Sigma EF500DG flash. The lenses I have (16-50/2.8, 50-135/2.8, F50/1.7) didn't bring me in a position that I needed that in the last 2 years (or I only use the camera on occasions that I have enough light ;-) ). As a walkaround lens I use my 18-135, which only sometimes doesn't give me the speed I would like to have. As said I addapt the gear to the circumstances I expect on my shoot.
Regards,
Mischa
10-21-2017, 04:11 PM   #25
jatrax's Avatar
QuoteOriginally posted by mischa72 Quote
I am sure it has to be something but honestly I leave mine on all the time and never noticed a drain. Except if the camera is not used for several weeks, I have had the battery dead when I picked it up then. Never a problem in my daily shooter which is now the K-1 but my backup has gone dead a couple of times. But that might have been a month between charges.
No significant difference in my shooting on a daily basis.
10-22-2017, 07:32 AM   #26
Insanely humble
savoche's Avatar
Not sure what you mean with "low-light performance"; the K-3II will definitely be better at focusing in low light, both speed and precision, but the K-5 has better dynamic range and I think they are about equal for high-ISO noise (at same resolution).
The K-3II is a better camera overall. Not massively at any point, but slightly improved in a lot of ways. The speed of operation and speed of focusing the most notable to me - especially when picking up the K-5 once in a while.
10-23-2017, 01:38 AM   #27
mischa72's Avatar
QuoteOriginally posted by savoche Quote
That's exactley what I need
10-28-2017, 06:16 AM   #28
kshapero's Avatar
Staying with my K-3 for now.
camera, dslr, k3, k3 vs, k3ii, photography
K3ii vs K3 vs K5ii seachongo Pentax DSLR Discussion 43 07-24-2017 02:02 PM
K3 vs k3ii Nerdlinger Pentax DSLR Discussion 40 04-10-2016 01:19 PM
ks2 vs K3 vs K3II Canukdragon Pentax K-3 5 09-28-2015 12:42 AM
Contrast detect AF on K3 (and K3II) vs. K-01 yorik Pentax K-3 3 08-25-2015 07:56 AM
Pentax K3 vs Pentax K3II, mp...? Leonski, Macedonia Visitors' Center 3 05-05-2015 12:16 PM
All times are GMT -7. The time now is 12:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
