10-18-2015, 08:44 PM   #1
k10D shutter firing erroneously
hello all, I have a broken K10D it fires the shutter* when any button is pressed, excluding AE-L, the metering modes lever, SR lever, flash, and focus lever. Every other button, control wheel, or lever causes the shutter to fire, halve press of the shutter button causes it to fire preventing a full press (same with cable release) it will also occasionally fire at random without being touched. no data is saved to the card. Any advice on what might be the problem would be helpful. I'm not sending the camera back to pentax as im sure it will cost more to fix than the camera is worth, and I have another K10, i just want to see if i can fix this one for my own amusement.
thanks
*(well actualy its too fast, sounds like around 1/50, to see if the curtain is firing, but the mirror is for sure)
10-18-2015, 09:24 PM   #2
calsan's Avatar
Try swapping the battery with the one in your other K10d and see if that fixes anything.
button, camera, causes, dslr, fire, k10d, k10d shutter, lever, photography, press, shutter
K3 II shutter doesn't stop firing decpi Pentax K-3 11 09-29-2017 06:35 PM
Adapter Q shutter not firing with FA 50mm? MD Optofonik Pentax Q 4 09-21-2014 08:18 AM
spotmatic shutter not firing punkrockpete Troubleshooting and Beginner Help 7 03-05-2014 08:29 PM
Shutter firing randomly IanF Pentax K-r 2 01-19-2012 08:25 AM
K200D shutter auto firing fractal Pentax DSLR Discussion 21 05-01-2010 04:34 AM
All times are GMT -7. The time now is 02:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
