10-25-2015, 03:32 PM   #1
Rayn's Avatar
K-3 II rear curtain flash issue (not lag)
My K-3 II is driving me insane... It occasionally seems to miss the sync with the flash, causing underexposed images (the flash goes off, but it seems to go off at a much lower power). This happens with my Metz 48 AF-1 in P-TTL, and after some experimentation I've noticed it happens usually in rear curtain sync mode with the flash head set to bounce. The biggest problem is it works fine 70% of the time, and than just randomly underexposes the image. I first thought the flash was the problem, but it works fine on my K-500, and after contacting Metz, they claim it should work fine. I've also notice this happening on occasion while using a radio trigger with the flash in manual mode, so it would appear the K-3 II is at fault here, right?
Anyone else experience a similar problem? Even though it's under warranty, I'd really prefer not to return the camera and wait 30+ days for a new/fixed one, so any ideas are appreciated.
Here's an example. Both pictures were taken 2 seconds apart in manual mode with identical settings (yes, the flash was re-charged).
PENTAX K-3 II  Photo
PENTAX K-3 II  Photo
10-25-2015, 04:37 PM   #2
MJSfoto1956's Avatar
I've seen that too.
But I don't have any specific details to add to your plight.
FWIW: there have been occasional "hiccups" with my Nikon system too, but nothing like 30% error rate.
M
10-25-2015, 06:48 PM   #3
The exif says the flash is in manual mode. What were the manual settings?
10-25-2015, 07:52 PM   #4
QuoteOriginally posted by Rayn Quote
It looks as if you took the pics immediately one right after the other.
Could this be recycle time? Taking a picture too soon one right after the other may not be giving enough time for the flash to recycle for the second picture. especialy if the batteries are low.
Regards, Dusty
10-26-2015, 04:25 AM   #5
Rayn's Avatar
QuoteOriginally posted by derekkite Quote
The flash was a hot-shoe mounted Metz 48 AF1 in P-TTL mode with rear curtain sync on (a flash setting in the flash itself), head vertical in bounce mode. Why it says manual in EXIF is a good question...
QuoteOriginally posted by Dusty Quote
Regards, Dusty
No, this was the first thing I checked.
10-26-2015, 10:14 AM   #6
If you called Metz you've probably already thought about it, but have you upgraded the firmware on the flash itself?
I have a 50 AF-1 and I was upset to see that the high speed sync was dimmer than I would have expected, to the point of not being useful. After more testing I realized that it wasn't syncing correctly with the shutter, so I checked and found there was an available firmware upgrade. After I upgraded the firmware on the flash it works great. It's a piece of cake to upgrade, but you will need a mini-USB cable though. (My, how quickly standards evolve - I had to dig for an old phone charger since all my current devices use micro-USB!)
10-26-2015, 11:42 AM   #7
Rayn's Avatar
QuoteOriginally posted by TheOneAndOnlyJH Quote
I'm afraid I already tried that, but the latest FW update was years ago and I have the latest FW installed.
This is a major issue for me as I often shoot club events, and this problem has already caused a few awkward situations. The irony is the K-500, my old camera, works just fine with this setup.
camera, curtain, curtain flash issue, dslr, flash, ii, ii rear curtain, k-3, k-3 ii, metz, mode, photography, sync
AF540FGZ II + K-3 Flash issue bebotette Flashes, Lighting, and Studio 12 10-08-2015 06:23 AM
K5, rear curtain sync flash in manual mode, advice on what flash to buy needed! 5R7 Flashes, Lighting, and Studio 4 03-25-2013 08:12 AM
rear curtain flash JP Myburgh Visitors' Center 2 08-20-2011 05:26 PM
Rear curtain flash on k200d iClick Pentax DSLR Discussion 7 07-12-2011 08:45 PM
Front / Rear Curtain flash question eccs19 Flashes, Lighting, and Studio 5 02-01-2011 07:05 AM
All times are GMT -7. The time now is 06:56 PM. | See also: NikonForums.com, part of our network of photo forums!
