Originally posted by link81 I would seriously consider getting another K50 or a K30. and replacing the screen in it. I use the focus peaking quite often for MF, and i don't think it was available before this generation.
Although, if you don't use it at all, i'd be tempted to look into something with a CCD (K10D is the latest i believe) Just because it would provide a slightly different look then your K50.
I was kinda thinking this would be my best bet but I'd rather not spend that much. It's really just for fun. If I could find a used one for like $100 (doubtful) then sure. Though I will be buying a k3 early next year so maybe I'll just turn my k50 into a MF camera. But any excuse to buy more gear is a good excuse in my book
So I'm ok buying an older body.
---------- Post added 10-28-15 at 11:38 AM ----------
Originally posted by pathdoc I would have used my *ist-DL for this, had it not been declared unrepairable when I finally submitted it to Pentax/Ricoh Canada. In fact, it was going to be not only my permanent MF lens camera but also my permanent Takumar camera. The only problem I would see with this is I'm not sure whether any of the aftermarket VF kits out there would be suited for it. It was a good platform while it lasted, and if it hadn't turned up toes just north of 10,000 clicks I'd probably still be using it.
I also kinda figured there wouldn't be much in the way of aftermarket screens for older stuff. But ill have to look into that.
