11-01-2015, 08:40 AM   #1
Pentax batteries
I have a young friend I'm helping get into photography. Her family bought her (I guess) a used Pentax k50. I'm a lifelong pentaxian and I have a K20d that I've used for four years, then I skipped right over the K50 to the K5II and the K3 in the past year. When her family bought the K50, apparently it didn't come with a battery charger. I don't know why. The K5II and K3 use the same battery and charger. Will that charger charge the battery that the K50 uses, which is apparently slightly different? Will the K20d charger work?
11-01-2015, 08:46 AM   #2
bertwert's Avatar
IIRC, the K-3 and K-50 use the same battery and the K20D battery is different.
You should be able to charge the K-50 battery with the K-3 charger, but not the K20D charger.
Please correct me if I'm wrong.
Don't attempt to charge unless my answer is verified by a more knowledgeable forum member.
EDIT:
K-3 uses D-LI90
K-50 uses D-LI109
K20D uses D-LI50
They are incompatible do not use with the other cameras chargers!
11-01-2015, 09:05 AM   #3
Once you confirm which exact serial number of battery you should order some of the packs of wasabi batteries. The ones I've bought not only had spare batteries but also a charger.
11-01-2015, 09:10 AM   #4
From what I'm reading, the K50 uses the D-LI109 battery and the K5II and K3 use the D-LI190 battery. Physically, they look similar. I still haven't figured out if the chargers are compatible. They come with different chargers.
11-01-2015, 09:10 AM   #5
THoog's Avatar
QuoteOriginally posted by jhacker Quote
QuoteOriginally posted by bertwert Quote
NO! The D-Li109 (K-r/30/50/500/S1/S2) battery will not fit in the D-Li90 (K-7/5/3/01) charger.
11-01-2015, 09:10 AM   #6
bertwert's Avatar
Here is the genuine charger on BH Pentax K-BC109 Battery Charger Kit for D-LI109 Battery 39033 B&H
---------- Post added 01-11-15 at 09:12 ----------
K-3 uses D-LI90 and K-50 D-LI109 THEY ARE INCOMPATIBLE
QuoteOriginally posted by THoog Quote
NO! The D-Li109 (K-r/30/50/500/S1/S2) battery will not fit in the D-Li190 (K-7/5/3/01) charger.
My mistake, I corrected my post as you were writing this
11-01-2015, 09:16 AM   #7
AquaDome's Avatar
The K-50 DOES NOT use the same battery or charger as the K-3.
The K-50 has the D-Li109 7.4V battery and uses the D-BC 109 charger.
The K-3 has the D-Li90 7.2V battery and uses the D-BC 90 charger.
Look for a used D-BC 109 on ebay or find an aftermarket battery with charger on Amazon.
11-01-2015, 09:21 AM   #8
bertwert's Avatar
QuoteOriginally posted by AquaDome Quote
I corrected myself as you typed this.
I misread the battery product nums as they are similar.
See my corrected post above.
11-01-2015, 09:30 AM   #9
I think we've solved the problem. Thanks.
11-01-2015, 09:32 AM   #10
THoog's Avatar
Yeah, it was SUCH a bad idea to call the one battery "109" and the other "190". (I know it was originally "90", but they could have skipped straight to "290").
Edit: some sellers list a D-L190 or sometimes D-li190, but it should be D-Li90 or D-Li90P (newest version)
I second the recommendation to find a used Pentax charger if possible. I have the Wasabi, and use it for travel, but it charges faster and heats the battery more, which will shorten life.
11-01-2015, 09:42 AM   #11
Another question. Can the battery be charged through the k50 camera with the right cable?
11-01-2015, 09:52 AM   #12
THoog's Avatar
No. None of the Pentax DSLRs have that ability.
11-01-2015, 10:59 AM   #13
Sadly.
11-01-2015, 11:03 AM   #14
buy them battery adapter with 2 set (4 each) eneloop battery and quick charge charger, i think that's will help them also
11-01-2015, 01:52 PM   #15
The K-50 shares its battery only with the K-r, K-30, K-500, K-S1, and K-S2. The battery model is the D-Li109 and the corresponding charger is the D-BC109.
For the K-50, you can also get an AA battery holder (D-BH109) instead of using the dedicated battery.
Third-party knock-offs of all of these accessories are out there. I recommend that you check reviews before buying anything that isn't genuine. Wasabi products (as mentioned above) do work well.
battery, camera, charger, d-li109, dslr, k20d, k3, k50, k5ii, pentax, photography, post
Re Batteries Quick Question Tom777 Pentax K-3 6 04-15-2015 09:46 AM
lr44 batteries in Pentax MX and Nikon F2 columb Troubleshooting and Beginner Help 3 06-20-2014 03:54 PM
replacement batteries for K-7 D-Li90 Nelleke Visitors' Center 8 02-24-2014 03:09 PM
Eneloop Batteries for Pentax K-x (Australian Prices) kwetiaw Pentax DSLR Discussion 21 11-13-2010 07:55 AM
Non Pentax batteries and remote control Palu Guimaraes Pentax DSLR Discussion 10 05-06-2007 08:52 AM
All times are GMT -7. The time now is 07:07 PM. | See also: NikonForums.com, part of our network of photo forums!
