11-02-2015, 04:21 PM   #1
Using Aperture Ring
I have a mix of Pentax lenses, including some with aperture rings and an "A" setting and those with aperture rings that are fully manual, i.e. no "A" setting. On the latter you need to set the menu item "Using Aperture Ring" to "enable." What I'm wondering is if it makes any difference to leave that set that way (enabled, or "2") all the time? I generally leave my lenses on A if they have that, and sometimes would forget to turn that setting back to 1. But as far as I can tell it doesn't matter...or does it?
11-02-2015, 04:28 PM   #2
It does not matter. It is better to leave it enabled so there is not a problem when you use your manual glass. Auto focus lenses are not affected by this option being enabled.
11-02-2015, 04:29 PM   #3
Aaron28's Avatar
leave it on enable.........I do it on k-r and k-50 no problems
11-02-2015, 04:42 PM   #4
Wingincamera's Avatar
On my K-5 II and now on the K-S2 I leave it "on" all the time. No problems.
11-02-2015, 04:50 PM   #5
PeaceFroggy's Avatar
Using a K-500 and noticed no problems with leaving it on
11-02-2015, 05:18 PM - 1 Like   #6
I think the *real* explanation for that setting is:
"Allow exposure when no lens detected."
As far as the camera body is concerned, Pentax-M = no lens due to no electrical contacts on the M's. Same for bellows or a reversed lens.
11-02-2015, 06:35 PM   #7
QuoteOriginally posted by Jinnax Quote
Ding! Ding! Ding! We have a winner!
11-02-2015, 06:40 PM   #8
Not a Number's Avatar
Well, not exactly given how different models handle painted/coated rear lens mounts vs bare metal lens mounts. My K10D doesn't care - the green button in manual mode will actuated the stop-down lever. I believe on the K30/K50 the green button will not actuate unless at least the data pin is shorted out.
aperture, camera, dslr, lenses, photography, rings
Using FA77 manual aperture ring on K-5 iis dhp. Pentax SLR Lens Discussion 14 12-18-2014 04:03 AM
HELP re: USING APERTURE RING info RioRico Pentax DSLR Discussion 11 07-24-2011 07:53 PM
Using the Aperture Ring on Auto Focus Lenses agsy Pentax DSLR Discussion 9 10-12-2010 10:51 AM
Sears 135mm f2.8 K-mount -- using aperture ring? bikerboy_ro Pentax SLR Lens Discussion 5 11-27-2008 02:20 PM
Using aperture ring? audiobomber Pentax DSLR Discussion 6 10-07-2008 02:31 PM
All times are GMT -7. The time now is 11:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
