11-07-2015, 07:24 AM   #1
Center point AF k50 vs k3
I've been wanting to upgrade to a k3 (from k50) for the improved AF but I currently only use center point AF so will it even make a difference? I tried looking it up but it sounds like center point is center point regardless of how many other points there are. And should I be using something other than center point for day to day shooting? I've never really messed with it so dunno if it will improve anything. Thanks
11-07-2015, 07:34 AM   #2
If you use fast lenses (2,8 ;1,8 ...) selecting the AF point will help you with the sharpness
on this shot is have used the af point on the right eye but is isn't as critical as it could have been with a longer lens (77/1,8 etc)
11-07-2015, 07:35 AM   #3
I thought the center point was the most accurate. And yes, most of my lenses are 2.8 and faster.
11-07-2015, 07:39 AM - 1 Like   #4
UncleVanya's Avatar
I see some improvement accuracy in my k3 over my k50 using center point, mainly in low light.
11-07-2015, 08:25 AM   #5
QuoteOriginally posted by Another dyemention Quote
IT may depend on the lens (field curvature etc)
11-07-2015, 08:38 AM   #6
mee
QuoteOriginally posted by AldaCZ Quote
Not if you use center point, gain focus lock, and recompose...
11-07-2015, 08:49 AM   #7
QuoteOriginally posted by mee Quote
IF you use AF-C then its fine but the DOF/Plane of focus moves and it can mess the shot.
11-07-2015, 09:27 AM   #8
KDD
Who win???
11-07-2015, 09:34 AM   #9
virusn3t's Avatar
From a k30 to k3 user... The center point AF is faster, more accurate and decisive when focus.
11-07-2015, 09:49 AM   #10
tgchan's Avatar
QuoteOriginally posted by virusn3t Quote
Sorry for stealing the thread, but...
I am looking to upgrade from my K-50 to K-3 but I am having a hard time with deciding if it is worth the money and hassle. I know 24mpx and 14bit raws would be bloody nice, but is there any noticeable improvement in terms of image quality?
I am using 35mm hd limited and I am not really impressed with the quality
11-07-2015, 10:05 AM   #11
QuoteOriginally posted by tgchan Quote
You may have checked already but are you sure the focus is spot on? I thought a few of my lenses were crap but after I really checked and adjusted the focus, the images were perfect. I wouldn't ever need anything sharper than what I get with my k50. A bit more resolution on far away subjects with fast primes would be nice but that's it really.
---------- Post added 11-07-15 at 10:13 AM ----------
After doing this for two years now, I've come to realize that 99% of my issues are operator error. Of course ymmv. I can blame my equipment all I want but when I really take the time to get the knowledge needed to address a problem correctly, I almost always find out it was my fault.
---------- Post added 11-07-15 at 10:23 AM ----------
And just like this post. I'm pretty confident that in the end, I'm going to find out that any focus issue I have, is my fault. Maybe I need to use a different setting depending on the lens I'm shooting with. I hope that's the case. I'd rather spend $280 on a second k50 than 650 on a k3.
11-07-2015, 10:52 AM   #12
virusn3t's Avatar
I dont have the 35mm macro, but the dfa50 and dfa100macro, both give me very sharp images on the k30 and the k3 too, the k3 allows me more crop wich is good for my kind of photography, so, yes the k3 withou AA filter give more details, and a overall crisp images but dont make the lens "a new lens", maybe you can fine adjust the focus or maybe is something wrong with the 35mm, the only drawback on my upgrade is that all my presets dont work on the k3 as they used to work on the k30 and maybe the diferent button layout, but everything else is a upgrade on terms gear and functions
11-07-2015, 11:14 AM - 1 Like   #13
Back to the OP's question...
The center column of focus points on the K-3 all feature f/2.8 focus sensitivity and will provide superior precision over the K-30/K-50 when used with lenses wider than f/5.6 maximum aperture. That does not mean the K-30/K-50 AF center point sucks (it does not), but does mean that your percentage of acceptable AF results at center will be higher.
11-07-2015, 11:17 AM   #14
I think the biggest improvement of practical significance is the -3EV sensitivity. This makes the AF faster in low to moderate light, and also more precise in very low light.
11-07-2015, 11:19 AM   #15
Looks like I'll be spending $650 then
---------- Post added 11-07-15 at 11:23 AM ----------
Seriously though, with my decision to focus on concerts, it's pretty much a no brainer then. I do think in se cases I should be using maybe AF-a and 5 point auto on my
K50 though. Especially when taking pictures of my three year old. He sits still a bit longer than he used to but he's still hard to chase around.
af, camera, center, day, dslr, fault, focus, hassle, image, k-3, k-50, k3, k50, money, photography, post, quality, time
K3 vs K50 nonstopnick Pentax DSLR Discussion 26 10-28-2015 02:16 AM
K3 center focus point slip Pentax K-3 17 06-26-2015 10:40 AM
K3 vs. K50 weather protection WaveDancer Pentax K-3 7 04-18-2014 03:06 PM
Size of K-3 center AF point vs. K-5? twitch Pentax K-3 23 11-17-2013 10:14 PM
AF point off center?? Judd Pentax DSLR Discussion 5 10-31-2009 05:38 PM
All times are GMT -7. The time now is 09:25 AM. | See also: NikonForums.com, part of our network of photo forums!
