11-09-2015, 09:16 AM   #1
Lens cleaning for K-50
I recently upgraded from a Kx to a K-50 and was disappointed to find that the latter did not have a way to check for dirt on the sensor. I found this was very useful on the Kx to decide when the sensor should be cleaned. Why would Pentax remove such a useful feature in a later model camera? Do they save money this way?
11-09-2015, 09:20 AM   #2
bertwert's Avatar
You can clean the sensor in the K-50 when starting up on shutting down. It uses the SR system to go this. SHakes the sensor.
As for sensing when it needs proper cleaning - I'm not sure.
11-09-2015, 09:29 AM   #3
ramseybuckeye's Avatar
I question why they removed that feature too, now I have to go take a picture of the sky or a white paper, download it, and look for the spots. Kind of a step backwards, but the improvements far outweigh it
11-09-2015, 03:10 PM   #4
QuoteOriginally posted by bertwert Quote
Yes, one can clean the sensor upon startup of the camera. That has not changed from the Kx. However, it would be nice to know if the sensor has gathered any dust beforehand so that cleaning may not be needed.
11-09-2015, 05:09 PM   #5
jeffw's Avatar
Found that feature useful on my K2000 and was disappointed it was not in the K30.
11-09-2015, 05:56 PM   #6
QuoteOriginally posted by jeffw Quote
I apologize for mis-titling my thread. I should have called it "Sensor cleaning for K-50".
11-10-2015, 02:08 AM   #7
Grippy's Avatar
I got a sensor cleaning pen, haven't used it on the K50 yet and only had to use it on my Oly E3 once. Quick, clean and easy.
11-10-2015, 05:37 AM   #8
QuoteOriginally posted by Grippy Quote
Is it for spot cleaning? If so, you would have to know exactly where the dust location is, to remove it. I've used a broader flat swab that proved effective for a stubborn "caked on" dirt spot which I could see with the naked eye. It was caused by an accidently dunking of my Kx in a stream when I fell. In this case a small pen type cleaner would be ideal I think.
11-11-2015, 12:05 AM   #9
Grippy's Avatar
QuoteOriginally posted by P. Soo Quote
It's for cleaning the whole sensor.
II took a pic of the white ceiling, looked for dust spots (they were stuck on as the sensor shaker thing did a pretty good job otherwise), put it in service mode that locks the mirror up (Oly E-3) and used a torch and magnifying glass to check the sensor before and after wiping. I could clearly see the tiny stuck on specs.
11-11-2015, 01:23 AM   #10
Des
Des's Avatar
Yes a loupe is good for this. The ones with a cutaway to insert a cleaning tool would be ideal.
camera, dslr, k-50, kx, photography, sensor
Can I use [Pentax K-30 lens guide] for K-50? lilcarp87 Pentax K-30 & K-50 7 06-05-2015 07:14 PM
First lens for K-50 for beginner alipop Pentax SLR Lens Discussion 35 12-17-2014 09:41 AM
Budget lens for K-50 dppa Pentax SLR Lens Discussion 13 12-16-2014 08:01 AM
Lens suggestions for K-50? watchingskyfallatm Pentax K-30 & K-50 19 10-22-2014 05:47 AM
General lens/mirror/sensor cleaning for noobs? Pentax K-x maxwolfie Troubleshooting and Beginner Help 15 07-20-2010 09:45 AM
All times are GMT -7. The time now is 02:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
