11-18-2015, 10:15 AM   #1
BigMackCam's Avatar
Is there a guide or summary of how the in-camera sharpening modes work?
I'm looking for information on how the different in-camera sharpening modes (Sharp, Fine Sharp, Extra Sharp respectively) affect JPEGs. Is there a useful summary anywhere, or can anyone give me a breakdown, please? I tend to shoot RAW these days, but I'm trying to optimise my JPEGs for when I want to use an image straight out of the camera. Thanks in advance
11-18-2015, 11:50 AM - 1 Like   #2
Just1MoreDave's Avatar
One reason to install the Pentax software is to shoot a test RAW, then apply the in-camera settings to it, just to see those effects on a big screen. Then you can set the camera up better.
11-18-2015, 12:06 PM   #3
BigMackCam's Avatar
QuoteOriginally posted by Just1MoreDave Quote
That's a good tip - previously, I've always just brought up JPEGs in a viewer and toggled back and forth to LR6 to see the difference between JPEG and RAW. Thanks for this I'd still be interested to know what standard Sharp, Fine Sharp and Extra Sharp actually do differently, though - rather than simply accepting that one might look better than another in certain images (so far, I prefer Fine Sharp, but it's a close run thing - sometimes Extra Sharp seems to give a better result; I just don't know why!).
11-18-2015, 12:09 PM   #4
There's no official summary, but think of the modes as progressively smaller Radius settings, and the ticks as +- sharpening strength
11-18-2015, 12:27 PM   #5
What camera do you have? If it doesn't have an AA filter I would set sharpening to 0 or -1, as otherwise you'd get something like this:
JPEG (K-S2 with default sharpening)
RAW:
The bottom line is that oversharpening on a camera that's already very sharp will backfire.
11-18-2015, 12:33 PM   #6
bertwert's Avatar
Like blank?
11-18-2015, 01:06 PM   #7
BigMackCam's Avatar
What camera do you have? If it doesn't have an AA filter I would set sharpening to 0 or -1...
... The bottom line is that oversharpening on a camera that's already very sharp will backfire.
Thanks Adam. I'm using the K3 & K5 currently (K3II waiting in the wings, lol) - so, your advice would hold true for the K3 (assuming no use of the AA simulation, presumably?), but as the K5 has an AA filter, I may need a positive setting for sharpening, right?
Also, since at 0 setting the camera is still presumably carrying out some degree of sharpening (unless minus settings soften the image?), which one do you recommend - the standard, fine or extra sharpening? Lastly, regarding the K5, do you have any idea what level of sharpening (and which sharpening mode) gives the best overall balance between sharpness and artefacts?
Thanks again
11-18-2015, 01:14 PM   #8
Can't say for the others, but I've settled on Fine Sharpening +2 on my K-5 II.
11-18-2015, 01:20 PM   #9
BigMackCam's Avatar
QuoteOriginally posted by Giklab Quote
That's exactly where I have the K5 set right now Thank you
11-18-2015, 01:35 PM   #10
It's going to have a lot to do with your lenses, the aperture used as well as your focusing and focal length. I don't think there can be a sharpening setting to suit all.
I keep my IC sharpen settings fully to the left.
11-18-2015, 01:35 PM   #11
Paul the Sunman's Avatar
Check out the following (old) discussions and demonstrations relevant to the K5:
neocamera
DPReview thread
Comparing K5 fine and extra sharpness DPReview thread
11-18-2015, 01:41 PM   #12
For some years ago I found two articles/posts describing the differences on the in-camera sharpening with a K-7:
Pentax K-7 Sharpness Settings | Neocamera
What do sharpening S, FS and FS2 mean (K7)?: Pentax SLR Talk Forum: Digital Photography Review
This may be interesting for you.
11-18-2015, 02:00 PM   #13
BigMackCam's Avatar
QuoteOriginally posted by Steve.Ledger Quote
Thanks Steve. And that gives you sufficient sharpening for your in-camera JPEGs, as a general rule? I get that optimal sharpening will be on a lens-by-lens - heck, even an image-by-image - basis, but I'm really looking to set a good general sharpening level that I don't change, so my JPEGs are as serviceable as possible without further processing. Most of the time I work with RAW anyway, using LR6 to carry out PP.
---------- Post added 11-18-2015 at 09:02 PM ----------
QuoteOriginally posted by Paul the Sunman Quote
neocamera
DPReview thread
Thank you, Paul I've started reading through those links and it's interesting stuff. Hopefully I'll reach a conclusion from this and my own tests (probably the wrong one, but better than none! )...
11-28-2015, 04:47 AM   #14
That's why I never touch the sharpening setting. I shoot raw and I let DxO choose the best sharpening setting for each lens from their measurement profile. It also take care of getting more uniform sharpening (apply a bit more on border than center) and avoid to sharpen out of focus area to not add to much artifacts.
I think that a bit what the diffraction setting does in camera.
11-28-2015, 06:42 AM   #15
BigMackCam's Avatar
QuoteOriginally posted by Nicolas06 Quote
I also shoot RAW and use LR6 for sharpening and other post processing... my reason for looking at the in-camera sharpening options was to allow me to get the most useable JPG images in-camera for those occasions where I want a JPG straight away (rare, but increasingly I find this would be useful)...
camera, dpreview, dslr, guide or summary, in-camera, jpegs, k5, modes, photography, summary, thread
Effect of in-camera sharpening levels on bokeh PDW Photographic Technique 3 10-18-2015 09:42 AM
Is there a in camera image counter for the K-50 or KIIs? Ghunter Welcomes and Introductions 10 06-24-2014 01:00 AM
Is there a in-camera timer for bulb exposure? weijen Pentax DSLR Discussion 16 05-16-2014 07:48 PM
Is there a WR Version of the 18-250mm lens or something close to the same focal range stl09 Pentax SLR Lens Discussion 11 05-02-2010 06:01 AM
In your opinion, which is better... in camera sharpening or photo editor? slip Pentax DSLR Discussion 17 12-05-2006 03:35 AM
All times are GMT -7. The time now is 12:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
