06-26-2008, 10:10 AM   #1
bluebronco's Avatar
What to do?
I am a relative newbie to photography.
I have a Pentax K100D
18-55mm Pentax AF lens
70-200mm Pentax AF lens
I am wondering if I should trade my two lenses for an all in one lens that covers the same range.
I want the flexibility of a wide angle with the zoom capability without caring 2 or 3 lenses.
Sorry if this has been hashed already.
I appreciate your input.
Thanks
06-26-2008, 10:19 AM   #2
offertonhatter's Avatar
I take it that the 18-55 is the kit lens. Also what age/speed is the 70-200?
If you must go for an "all in one" lens, I would suggest the 18-250mm F3.5-6.3 as this will give you flexability. All this depends on the Speed of the 70-200. If if is a fixed fast aperature (say F2.8 or F4) then you are better of getting a better wide zoom, such as the 16-45 F4. However, if it is veriable aperature wide open, then the 18-250 would be a better bet as it would you give you better optics than you currently have.
Hope this helps.
06-27-2008, 07:25 AM   #3
bluebronco's Avatar
The 70-200mm is a Pentax SMC-FA 1:4-5.6. It has a little age on it.
af, camera, dslr, lens, lenses, pentax, photography
All times are GMT -7. The time now is 07:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
