06-28-2008, 09:15 AM   #1
Image count on K200D has shifted to a high number
I used the same memory card between a K100D Super and a K200D. The image count on the Super was about 6000 and on the new K200D was about 800. After I formatted the card I have noticed that the new K200D is showing image count about 6000 as well. So it looks like a lot of pictures were taken with it but in reality only 800 pictures were taken. Does anybody have any ideas how to correct that? I am worried if and when I want to sell the K200D the high number of images would become a problem.
06-28-2008, 10:32 AM   #2
morfic's Avatar
Then check the shutter count with PhotoME, and provide the buyer with that number instead of the image number.
Pentax at least provides that number, other brands do not.
06-28-2008, 10:36 AM   #3
Ole
Ole's Avatar
Use PhotoME as morfic suggests. You cannot count on the image number anyway since the image number can be reset to 1 in a custom function.
06-28-2008, 10:38 AM   #4
lequynorm's Avatar
In what body did you format the card??
06-28-2008, 11:10 AM   #5
LeoTaylor's Avatar
I don't know about the K200D you have, but the way I "fix" the count when I accidentally mix my K100D and K110D cards is:
Change the Setup menu option "File #" to Reset. Power off.
Put a single file on a card using your computer with the old count either by copying your last correctly numbered file or editing the file name.
Insert prepared card, power on.
Take a test shot, it should have a name one greater then the file you placed on the card.
Change the Setup menu option "File #" back to SerialNo.
06-28-2008, 11:41 AM   #6
Thanks guys. I downloaded PhotoME and found out what the real shutter count is. Then I followed the procedure outlined by Leo and set the file number in the camera the same as the actual shutter count. Now they are in sync. Great.
06-29-2008, 05:52 PM   #7
LeoTaylor's Avatar
Stratario,
I'm glad my little procedure worked for you. I occasionally use my K110D card as a spare for the K100D and mess up the numbering. It only takes five minutes to fix.
Hint: My K100D rolled over 9999 a few weeks ago. A strange directory appeared on the card called 101PENTX. Unfortunately I read that as 110 and assumed I swapped cards and I erased the directory. Then I discovered a bunch of files were missing. The camera does not put 0001 in the same directory as 999x, it created a new folder.
Fortunately I purchased "Easy Photo Recovery" before when I needed to recover some corrupt images (only partially successful). The program had no trouble un-deleting the folder of photos. Afterwords I deleted 101PENTX and the camera went back to "normal."
camera, card, count, dslr, image, image count, k200d, photography, pictures
Image Count info...Actuations on KX dzn465 Troubleshooting and Beginner Help 3 01-13-2010 12:58 PM
Actual RAW file size and recordable image number Matjazz Pentax DSLR Discussion 12 04-01-2009 04:33 PM
brand new K10D high image and click count generic Pentax DSLR Discussion 28 06-28-2008 07:58 AM
:( Sox fan in NY (high picture count) fun things you see when your team is losing. vievetrick Post Your Photos! 3 09-05-2007 05:20 AM
K10D image count ChrisN Pentax DSLR Discussion 0 12-01-2006 09:09 PM
All times are GMT -7. The time now is 09:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
