Originally posted by Spooked Net here on samos island, hence the delay with replies. Sorry guys. thanks for your informative replies. However the questiom of whether this is normal behavior in m mode still stands? If so then what is the possible scenario for its use. Sorry for errors, this is first time using net on my phone. Its tiresome. Thanks for the help everyone. Peter
Yes, it is normal. If what Procyon says is true, then use P-mode to set the exposure manually, and just make sure that the aperture is the last setting you dial in. I suppose Pentax figured that if you are shooting in manual already, you would do your own bracket.
